301A
smigelski
10-31-2007 16:08:44
I have to pump the breaks several times for them to work, also when the hyd. fluid gets hot the 3 point stops working. the fluid level is fine.
ET
11-01-2007 05:57:31
 Re: 301A in reply to smigelski, 10-31-2007 16:08:44
You could try bleeding you brakes by putting a clear piece of fuel line on the bleeder (there is one on top of each final drive) and routing it into the fill hole on back. Bleed them like any automotive brake, pump it up and open the bleeder, close the bleeder and pump the brakes bake up. Do this until no more air bubbles come out. Have the engine running to supply oil to the brake valve. BUT adding in the hydraulic problem the brake linings are probably shot and are now pluging your suction screen. You should pull it and see whats in it.
