Power Block
Ben Rauls
10-30-2007 13:57:27
I found a power block for my B, how far can it be safley bored? The guy says it has pits says 90thousands should take care of them. Its the on ein the photo ads for $595.
Ben
buickanddeere
10-30-2007 20:06:40
 Re: Power Block in reply to Ben Rauls, 10-30-2007 13:57:27
I sleeved the sleeves in th 5-3 power-bloc in our 50. Seems to run fine. The power-bloc sleeves were very soft when we machined them. The TSC pistons & rings showed very little wear however the bore was so egged out. A 45 thou overbore didn't clean them up.
WTW
10-30-2007 14:33:54
Ben, I was going to call on that block too, but didn't. If you got it bought I won't bother. You can bore them out as far as .125. I have bored many this far. One of my own PB's has just finished its 17th season since it was put together with .125 overbore on its stock original PB sleeves. The problem you will have is finding a piston that will be close or .090 over the standard power-block bore. A 5" bore is really an odd size when it comes to finding pistons. I have used different pistons but the key to the correct piston is what cylinder head combustion chamber size you are working with and cylinder volume created by what stroke you have. It will make a good component if you have all other combinations to go along with it. If you are planning on running a stock stroke and cylinder head with it plan on having custom made pistons made for it as well as you will not be able to find any (off the shelf) piston to even come close to achieve the compression ratio you will need unless it looks and is shaped like the original PB piston. There is/was no such thing as OEM oversize pistons for these power-blocks. Let me know if you need some help. Good Luck,DW
Ben Rauls
10-30-2007 15:48:09
 Re: Power Block in reply to WTW, 10-30-2007 14:33:54
It comes with the 5" PB pistons, could it be resleeved to 5"? What does a set co custompistons cost?
Ben
jd b puller
10-30-2007 18:58:15
 Re: Power Block in reply to Ben Rauls, 10-30-2007 15:48:09
Ben, what are you going to do with the tractor? Pull or farm. Kinda makes a difference what your options are for pistons. As WTW said, there aren't any OEM Oversized ones out there. Custom ones are funny too, due to the large compression height. I can get you custom ones if needed, but I'd rec just boring it to 5.125" and not resleeving. Just more work to resleeve and no real benefits. Not sure where you'd find a sleeve for it either, unless you leave the original sleeve in there and just bore it where it's real thin and put the new sleeve inside the old sleeve. All the sleeves I use are 0.125" sleeves, vs. the 0.1875" sleeves that they are now.
