49' Model M ruinging batteries and won't start
Bradley Rausch
10-30-2007 12:11:04
My M has been switched over to a 12volt system. It will run good with a new battery for a couple of days and then it won't start. I bring the batteries back to be tested and they say they are bad every time. I installed a cutoff switch in the battery line to make sure something is not draining it. Anyone have any suggestions? Thanks! Brad
S. Crum
10-30-2007 21:19:50
 Re: 49' Model M ruinging batteries and won't start in reply to Bradley Rausch, 10-30-2007 12:11:04
Saw this same problem a few years ago in a 40. The guy that converted it to 12 volt with an alternator had the battery hooked up to reverse polarity. This only destroyed 1 battery but apparently that's how the alternator says it doesn't like reverse polarity. Hooked up correct polarity and it's been fine since.
John T
10-30-2007 14:54:43
Bradley, the problem sittin here is we have no idea when it was switched to a 12 volt system what all was done. 12 volt genny and converted to a Voltage Regulator or an Alternator or what???
You need to first determine if its charging or not and next determine if theres a minor short causing a slow trickle discharge (which the battery cutoff will cure) or a sticking cutout relay but it dont sound like that cuz that would run her down very quickly plus the genny would get hot. Also we have no idea sititn here if it was an alternator conversion if it was done right or has another alternator problem causing a slow discharge.
Bob has told ya how to tell if its charging as either a working ammeter should indicate such or else the batery voltage should rise from the normal 12.6 volts setting to the 13 to 14 range depending on what charging system it has.
John T
wilamayb
10-30-2007 12:27:06
Unless it is over charging them I think you have gotten into a bad batch of batteries.
Have you monitored the charging system?
Bradley Rausch
10-30-2007 12:36:52
 Re: 49' Model M ruinging batteries and won't start in reply to wilamayb, 10-30-2007 12:27:06
no how do i do that
wilamayb
10-30-2007 13:47:51
 Re: 49' Model M ruinging batteries and won't start in reply to Bradley Rausch, 10-30-2007 12:36:52
I'll add that usually there is a nasty sulfur smell that goes along with over charging.
Bob M
10-30-2007 12:44:29
Watch the ammeter!
1 - With the engine stopped, turn on the lights or ignition. The ammeter hand should deflect to the left of "0" indicating the ammeter is working and that the battery is being discharged.
2 - Then with the engine running at full governed speed the ammeter should hand should deflect to the right of "0" indicating charge. The farther the hand is to the right, the higher the rate of charge.
Alternatively stick a DC voltmeter across the battery posts. With the engine stopped the voltmeter should read about 12.6 volts for a fully charged battery.
Then with the engine running at full speed the voltmeter should show 14.0 - 14.5 volts if the battery is charging properly.
