Hand starting a 1948 A
GeorgiaHayFarmer
10-30-2007 04:21:13
Has anyone tried to handstart a 1948 A? It's not easy. What I'd like to know, is it possible? I have had mine pop so far but not start up yet. Also I asked a question about a radiator core a few posts down and would like to know if an A & I radiator core will fit in a 1948 A with a water pump? I have never had to replace a core before and don't need to install a 350.00 dollar core. Do the bolt holes line up and match or are they poorly engineered?
Thank you,
Scott
bucke eye al
10-30-2007 14:17:39
 Re: Hand starting a 1948 A in reply to GeorgiaHayFarmer, 10-30-2007 04:21:13
My A's are all early styled with mags. Most often used is the 1947 long hood. At 6 volts they just don't crank very well so I have the steering wheel starter spud welded to part of an old cultivator lever about 30" long. I most always start it that way compression releases open. I've many a time however been where the crank was NOT & started it by opening the compression releases, put it into neutral, engage the clutch & grab the belt pulley!
Word of advice..... you BETTER be friends with your tractor knowing what it wants & needs to start or you won't crank it this way for long! It's a tough roll but you do what you have to do with what you have at the time.
almrm
10-30-2007 07:14:14
I have hand started my 48 A many times in the past with the steering wheel and the chuck through the hubcap on the flywheel cover. I have a spare steering wheel just for this purpose. The tractor has a magneto ignition. After restoration, I used pipe plugs instead of compression releases to keep the belly dry. Needless to say, with a new engine and no compression releases, the hand starting days are over. The steering wheel and chuck are handy and still used for timing, tappit adjustment, or other diagnosis requiring the engine to be turned without the spark plugs installed.
Mark
F-I-T
10-30-2007 07:13:05
Yes, I have. Our '48, which was S/N 595751, had a Wico X distributor, and when the battery was down, I used the starter spud in the flywheel mounted in an old 4 spoke "G" steering wheel that I found at a farm sale for I think 25 cents. It was bent where the guys kid planted his forehead in it when he was backing out if a low-hanging doorway too fast. My dad in his early days with tractor used a pipe wrench on the spud. Yeooow!
Hopefully you have enough battery voltage for the distributor, or in the case of a mag, a good hot impulse trip. I can't say how easy yours will be to start, but I did cheat and remove the plugs, and sometimes warmed them if it was brutal cold, and squirted a teaspoon of gasoline in each hole, then open the petcocks, choke out, place your hands on the crank/wheel so that you are past the top when it hits on #1. I seldom could get it to hit on #2 and carry over. This one had aluminum high-compression pistons that Tractor Supply sold in the late 50's, so it was chore.
Now if the battery voltage was too low, I would unhook the distributor lead and hook an old "Hot-Shot" 6 volt drycell to it so I would have spark.
Now the next question is, have you ever hand-started an unstyled "A" wearing a mounted picker using the 6' long starter spud? That's a treat!
Hand-cranking that "A" engine will provide you quickly with an answer to the oft asked question "How do I tell the difference a Model A and a Model B?".
Frank
John T
10-30-2007 05:55:31
Not lately and dont plan to lol. Its one thing if you can open compression relief petcocks and have a nice hand hold to the flywheel but if theres sharp ring gear teeth (and gotta first remove the flywheel cover) I dont like the thought of that. Id pull start it then adjust the carb etc n then diagnose any carb or ignition problems.
John T
Dale West
10-30-2007 05:53:11
I have hand cranked these late styled "A"s and "B"s before but the ones I dealt with had magneto ignition. I don't know how they would be with battery ignition.
Mike M
10-30-2007 04:56:57
I have started those before,but not by hand,but rather by foot. This was on decent running tractors that had the fylwheel cover removed. You have to tie up the starter rod. Usually open the petcocks at the bottom of the block then climb up on and stand with 1 foot on the tire or or top of the crankcase and hang on to the steering rod/column and using 1 foot roll it over. I have one of the tools to use a steeringwheel in the access hole in the fylwheel cover but never used it for starting.
johns48jdb
10-31-2007 05:18:45
 Re: Hand starting a 1948 A in reply to Mike M, 10-30-2007 04:56:57
and your still alive to tell this tale. what would have happened if you had gotten your clothing caught in the fly wheel?
Mike M
10-31-2007 07:46:24
 Re: Hand starting a 1948 A in reply to johns48jdb, 10-31-2007 05:18:45
Same as if it got caught on a regular hand start fylwheel. If you stay up above and don't wear floppy clothes I still see it as safer than cranking one with a hand crank ?
