Hard starting A
Schrade88
10-29-2007 19:11:55
My nephew just bought a Model A it started alright when he got it but it needed some attention and after putting it back together it will not start by just cranking it over. If you pull it then it starts and runs. What are we missing or doing wrong. New plugs points condenser wires carb kit
chrisfromsolitude
10-30-2007 07:13:00
 Re: Hard starting A in reply to Schrade88, 10-29-2007 19:11:55
First thing I would try is to adjust the valves. Don't know what all you had apart but what I have seen if the valves are out of adjustment the only way you can get it started is to pull it. May change the plugs too. Let us know how it works out.
johns48jdb
10-30-2007 05:01:02
something you did caused the change. nothing should have broken causing the problem if it was all right before. chances are it the carb. if you don't clean/adjust them right it will give you a fit. also reset the timing. lossen the mag and turn it all the way to the left. turn the flywheel until its parallel to the ground and then turn the mag back to the right until it snappes and tighten it down there. its been 7 or 8 years since i did that but i think thats right.
430WLPG
10-29-2007 19:19:51
You didn't say what year it is,Or what kind of attenion it needed. Does it have a mag? If so the impulse spring may be broken or weak
