1950 JD A
kevin brambrink
10-29-2007 17:53:12
I have a 1950 A that has load knock in the motor when it is idling, but when you speed it up it seems to go away. checked the bearings and they seem to be in good order and adjusted right. Any other ideas would be great.
thanks kevin
F-I-T
10-30-2007 08:57:59
 Re: 1950 JD A in reply to kevin brambrink, 10-29-2007 17:53:12
Kevin,
Can you reduce the noise substantially by shorting out one plug, then switch to the other? Once the ignition and the impact of ignition is removed from a bum cylinder, the "knock" will often subside. It's a decent way to localize the problem to one cylinder or the other. It's pretty easy to check out the bottom end, rods and mains, so if you hear it at the top end, it is likely a wrist pin.
A lot of people "overhaul" these engines and never think about wrist pin bushings. I have seen so may egg-shaped bushings, and one in a '49 "A" that was worn so bad that it had almost broken through to the rod parent material.
Frank
Dale West
10-30-2007 06:02:44
I would bet on the noise being caused by the wrist pin. I have seen several "A"s that had this happen. New pistons and pins should take care of it. Or, you can run it like it is if you don't work it hard. A friend of mine has one that has been knocking for 15 years or so.
kevin brambrink
10-30-2007 04:52:14
I have gone through the first reduction gear as well as put new bearings and bushings in the clutch. Also have checked the flywheel and it is not loose. The noise is coming from the front of the motor in the block area.
thanks kevin
Will- Tx.-Mn.
10-30-2007 07:54:34
 Re: 1950 JD A in reply to kevin brambrink, 10-30-2007 04:52:14
Kevin,
It's got to be the piston,now that you say the noise is comming from the front of the engine..
I went to Gotvalds' in Minnesota,and bought a used piston from Dick for about $40.00 and that did the trick,it stopped knocking, and yes I put the rings onto the used piston,and it still runs today.. in fact one cold morning about forty below there in Mn. it was the only tractor that would start and I was glad when it started cuz it had the loader on it and it plowed out the driveway
~Will
Dandeere
10-30-2007 17:41:48
 Re: 1950 JD A in reply to Will- Tx.-Mn., 10-30-2007 07:54:34
Hey Will, I heard Gotvalds was for sale, I will sure miss them if they close. I have done business up there for over thiry years (good folks). Were you around when they had the spring auctions, and the young kids drove the tractors through the ring and old Pete selling them off, boy those were the days!!! Later,, Dan
Kurt_JDB
10-29-2007 19:35:31
This knock could also be caused by a loose first reduction gear. You can check this by removing the clutch assembly, and then reach into the first reduction gear cover, and grab the first reduction gear and see if it is loose on the tapered spline of the transmission input gear.
Kurt
430WLPG
10-29-2007 19:10:37
Did you check for a loose flywheel or clutch driver either can cause a knock
Will- Tx.-Mn.
10-29-2007 18:10:05
Kevin,
I had that noise on my A, ten years ago.. turned out it was the wrist pin, actually the piston (worn where the wrist pin is), hope this helps
~Will
