520 clutch whining
dh520720
10-29-2007 15:41:12
I just bought a 58 520 and started noticing under load that it will really whine but when there is no load it will not whine as much. I have been tld that this is normal and is just the way it is, but my old 720 and 630"s did not do this. Is it normal?
Mike M
10-29-2007 18:18:15
 Re: 520 clutch whining in reply to dh520720, 10-29-2007 15:41:12
Might not hurt to check the outer most bearing on the RH side of the input shaft. This is behind the little cap on the reduction gear cover. How is the tranny lube ? If old may be worth draining it and the reduction cover and then refill the cover and the tranny with some new gear lube. If in warm climate go to a heavier grade.
machinery-man
10-29-2007 16:24:13
comes from excessive wear on the reduction gear to clutch gear, the crown in worn off allowing teeth to strike flat. Not anything you can do unless you spend $$$$$$$
2cylinderlp
10-29-2007 20:22:11
 Re: 520 clutch whining in reply to machinery-man, 10-29-2007 16:24:13
What if you took the primary reduction ring gear off its hub, flipped it over and then put it back together? It would be unlikely that the crown is worn off the same amount on the reverse side of the gear. Of course that does nothing for the pulley gear, but maybe some crown on one of the reduction gears for the forward speeds would be enough to quiet it down?
machinery-man
10-30-2007 07:13:07
 Re: 520 clutch whining in reply to 2cylinderlp, 10-29-2007 20:22:11
I"ve never tried to removed the gear from the reduction gear center...believe this may be a special factory fit...anyway I"d check the bearing like Mike says...if okay then drain oil and go to a heavier oil maybe 140 and even put a couple cans of stp in the case...beyond this or trying to find parts with less wear which would be tricky it will be a live with proposition. I"ve found from working on the 520"s and 530"s a lot of them had a lot of life pulled out of them. If I were buying, I"d go to a region where they had larger tractors and these were just helper tractors. In Ky. Tenn. South the farmers wanted every penny they would get out of these and John Deere sold the as more power for the money.
Mike M
10-30-2007 13:12:07
 Re: 520 clutch whining in reply to machinery-man, 10-30-2007 07:13:07
Seems like the ones I have seen up here in Ohio were not used as much as other model tractors for some reason or another. alot more had 620,720,730 models and also once they came out 4010,4020 models lots of 4020's !
