Clutch on JD 50
gitrib
10-29-2007 07:06:14
Got the JD 45 loader off of 1956 Model 50. Moved in shop to start getting her to run, Clutch was the main concern. We noticed the lever to engage would not move. Took off cover plate and every part looked like it had been hot. OK we will just replace all of the plates and discs. Using the dealer service manual for instuctions. Everything was stuck together and corroded and rusty. They all finally came apart except the finally clutch drive which is on the end of the crank shaft. The service manual shows a disc behind it and to use a puller to pull it. Using the two drilled and tapped holes a puller was attached. Pressure was applied. Nothing would give and it bent the puller. This was a screw type and not a cheap puller it was a heavy one I have used for many years. We took the wheel and tire off so we could give the screw end a good blow with a hammer. Since this is a tappered fit is the next option applying some heat? If so how much? It is sure not cherry read. Can the clutch plates be resurfaced and smoothed enough to use?
We expect to use this as a working tractor. Never worked on a JD had a lot of experence on Oliver
JOHN DEERE 70
10-30-2007 04:02:12
 Re: Clutch on JD 50 in reply to gitrib, 10-29-2007 07:06:14
I HAVE BEEN USING THE BAR THAT, YOU USE ON THE THREE POINT HITCH WITH ALL THE HOLES IN IT FOR TOWING BY PUTTING A BOLT IN THE CRANK FAR ENOUGH IN NOT TO MESS THE THREADS UP,THEN PUTTING THE BAR ACROSS,THEN PUT BOLTS THROUGH THE BAR AND CLUTCH DRIVE AND TIGHTEN . BE CAREFUL OF YOU DRUM PULLEY.
RobMD
10-29-2007 15:07:42
it will come if you heat it with the puller on it... but i'll tell you what, those tapered splines just like to POP off, and i mean POP off, i had one that hit the screw of the puller on the inside of the tire, It actually left a mark in the tire.
Mike M
10-29-2007 07:12:28
Normally a good puller or one made from a piece of flat iron with holes in it for the bolts drawn up tight then give a good whack will free them up. You may need to apply heat if that won't do it ? Just put pressure on it then apply heat and you should hear it pop. I have used a sandblaster to clean up those metal clutch plates and driver disk. Works good even if they are not rusted because it deglazes them.
gitrib
10-29-2007 12:17:16
 Re: Clutch on JD 50 in reply to Mike M, 10-29-2007 07:12:28
Hey Mike got three pictures in Tractor Photos of the old gem. I am sure you will be hearing from me more as we progress. Thanks a lot. We will try to get it off tonight. Meaning I will watch in my whell chair while son does the work. Darned old knees no good after they were total replaced.
