JD 60 spewing power steering fluid.
Curtis Aberle
10-28-2007 21:13:54
I have a John Deere 60 that is spraying power steering fluid out of the filler cap. Any ideas would be greatly appreciated. Thanks Curtis
Bob
10-28-2007 21:47:43
 Re: JD 60 spewing power steering fluid. in reply to Curtis Aberle, 10-28-2007 21:13:54
If you are using the correct fluid, the most likely suspect would be a bad pump shaft seal, allowing air to enter the system
RobMD
10-29-2007 08:20:34
 Re: JD 60 spewing power steering fluid. in reply to Bob, 10-28-2007 21:47:43
Either that or pressure by-passing the steering vanes, which in turn actually pressurizes the steering reservior. It happens, and for those who have NOT fixed the vanes while rebuilding the top end of the power steering, the tear down yet again is very disheartening.
