John Deere LA Spark Plug Fouling Problem
AWB
10-28-2007 19:18:51
The Mag has been completely rebuilt and checks out. No bad sparkplug wires. Carburator has been rebuilt and the float os set according to JD specs. The tractor has been fully restored and the compression is at specs. The tractor will run fine for about 30 minutes and then starts to run rough. Take the plugs out and they are badly fouled. Clean the plugs put them back and the tractor starts and runs fine for another 30 minutes. I have been using Champion H-12 plugs. Any suggestions?
buck eye al
10-29-2007 14:09:59
 Re: John Deere LA Spark Plug Fouling Problem in reply to AWB, 10-28-2007 19:18:51
Warm it up & lean it down.
36 coupe
10-29-2007 04:35:02
Autolite 437.
AWB
11-01-2007 17:05:32
 Re: John Deere LA Spark Plug Fouling Problem in reply to 36 coupe, 10-29-2007 04:35:02
36 coupe: Thank you for the suggestion regarding the use of Autolite 437 Sparkplugs. Finally located some locally and will give them a try.
