Broke my B No gears
Matthew H
10-28-2007 17:12:24
My B is fairly new to me. I have done some fairly heavy rotary cutting, but I had not ask it her to pull from the hitch until today. I harrowed about 50 yards in 3rd gear (6 speed) when it just stopped (no noise of anything breaking). I can move the shifter into and out of the gears on the left side, including 3rd, with no effect. I cannot pull the shifter back enough to get it into the slot to try the gears on the right side. I can engage the clutch and the pto will operate as if the tractor is in neutral.
Ideas and/or good wishes apprecited.
machinery-man
10-29-2007 06:36:35
 Re: Broke my B No gears in reply to Matthew H, 10-28-2007 17:12:24
Sounds like your transmission was badly worn, bearings and with the strain you"ve jammed it up. I "ve been into many of these, the bearings have to be adjusted, lower shaft or replaced then adjusted. Generally the 1/3 gear has wear as well as the position in the upper shaft. There is a locker kit that I always installed, was a retro fit for a JD50 to keep 1/3/reserse from walking out. Better do a tear down and fix right if you plan on using much, otherwise next time you"ll hear clanging and teeth chipping off.
Kurt_JDB
10-28-2007 19:36:25
Matthew,
I'm betting that your Sliding Gear Shaft drive gear has disengaged from the transmission drive gear, most likely due to a worn detent on the shifter rail or broken detent spring. If this gear should move on the sliding shaft (which will move the shifter) you would not be able to get the gear shift stick all the way down and over to the other side, because the shifter opening in not in the right place.
The sliding gear shaft drive gear directs the power flow through the countershaft idle gear or through the countershaft first and third speed gear. When you are sliding the gearshift lever across the bottom of the selector box, you are setting this gear in one of these two positions. You are probably in between these two positions. PTO would still work because it is driven off of the Idler gear, which will always turn if the clutch is engaged.
Should not be too hard to get it back in place, but it may be worth tearing the tranny down enough that you can inspect your detents and replace the detent springs.
Good luck,
kurt
Bob
10-28-2007 17:14:23
Take the tranny cover off, and put the "wiggle stick" back in it's slot in the shift rails.
Matthew H
10-28-2007 17:30:10
 Re: Broke my B No gears in reply to Bob, 10-28-2007 17:14:23
Thanks - is there anything I should look for other than obvious wear that causes this in these tractors. ps. I did have her loaded heavy at the time. Thanks for your help.
BushogPapa
10-28-2007 20:40:11
 Re: Broke my B No gears in reply to Matthew H, 10-28-2007 17:30:10
You need to check and see why it didn't stay in gear... The detents should keep it in gear.. Just be Very happy that it didn't pop into 2 gears at once and blow out several expensive gears..!! I once saw a JD 70 Gas that had this happen and it stopped the engine so quickly that it sheared the splines off in the flywheel...!! You can put it back in gear by unbolting the shifter/steering mast and lifting it up and sliding the gear back in proper allignment.. The groove path should be a constant "U" shape, when it is in neutral.. Slip the shifter end in that groove, as you lower the shifter/steering mast back down, in place and bolt it down.. You may have to dis-connect the throttle and shutter rods to do this...and it probably would be easier if you took the steering shaft out of the way (out the front)... Best of luck..it should stay in gear..!! If it came out "in the field", it will certainly come out while travelling on the road...! BTDT..!! Ron.
