2240 fuel in crankcase
Stephen in SOKY
10-28-2007 16:04:09
I posted 2 weeks ago & a couple of guys suggested replacing fuel pump in an attempt to remedy (Thanks for the help!). Got a new one on and it's still putting diesel in crankcase. Does this mean injector pump? If so, where do I start searching for the leak? Are there other possibilities? FYI it's an early 2240 (1 owner). Thanks very much for your opinions.
jdemaris
10-28-2007 17:36:42
 Re: 2240 fuel in crankcase in reply to Stephen in SOKY, 10-28-2007 16:04:09
Does it have the Stanadyne/Roosamaster pump - or the CAV?
The Stanadynes often get a ridge worn into the bronze bushing at the front of the injection pump -causing diesel fuel to leak past the two umbrella seals. If so - the pump needs to come off - new bushing put in - and two new seals installed. It's a three hour job - start to finish for someone that knows what they're doing. And - about $15 total in parts.
R. DOANE
10-28-2007 16:36:39
if you have checked the transfer pump, the next plce would be the two seals on the inj. pump shaft. good luck. changed a few myself.
