4020 D Water Pump
TBM
10-26-2007 19:52:34
I bought a rebuilt water pump for my 4020 diesel. Looks like it should be simple enough to replace - except 1 thing. Looks like 2 ports (1 of them is for hte oil cooler) are not threaded. Abilene included 2 short pieces of tubing that appear to fit into these ports. Question is, how do I seal it so they won"t leak?
I"m not much of a mechanic and have zero experience with JD so hope someone out there knows and can share. Thanks
matthies
10-27-2007 19:17:51
 Re: 4020 D Water Pump in reply to TBM, 10-26-2007 19:52:34
Any sealer or loctite will work for the pipes they are a press fit anyway. I use loctite and tap them in with a hammer about a 1/2 inch. chris
Mike M
10-27-2007 05:14:42
I would be more in favor of rebuilding the one on the tractor. Not hard to do. Or most dealers will do them for you too.
Gerald J.
10-26-2007 20:56:35
There are several different versions of the pump, particularly where the bypass pipe connects. And on my gas tractor they weren't interchangeable, though the parts houses thought they were. I only got a pump to fit when I rebuilt with a JD kit.
Gerald J.
LarrySTN
10-26-2007 20:53:55
The water pump should have o-rings in the ports that the tubes will fit. Lube the tubes before inserting them in the pump.
Wisconsin Cowman
10-26-2007 20:18:50
I would say hose claps would work.
