Mark -- there are a number of indicators that can get you in the ballpark so far as vintage is concerned. Finding the precise serial number without a boatload of (say) old service data from a prior owner is about the only way I know to learn the s/n short the tag. The serial tag would be in one of two places, and both are located on the forward, upper region of the main case. If before H27,000, the tag would normally be located on the left side, and for H27,000-up, the tag would be on the belt pulley side. At minimum, in your search, you should be able to find two holes roughly 3 inches apart where there once was a tag. Don't give up. One indicator, provide the tractor wasn't outfitted for E-start, is the lower radiator water pipe. If it is round, the tractor most likely is below 27,000. If the pipe is sort of flat, and profiled below the front end support frame, this is 27,000-up configuration. H47,796-up have pressed steel front wheels whereas earlier tractors sported cast iron fronts. Look at the shifting turret: if it stands up some 4-1/2 inches and is mounted on a slant, the tractor is a '39-H (s/n below 10,000). There are a few other clues as well, but you will have to find a book or two on the "H" in order to learn of them -- the main one being PC304, the parts catalog. There are other good books on the "H" out there too. You can also learn a bit about the "H" tractor at the JD-H Restoration Site (below). While at this site, see also a buyer's guide for the "H" tractor. (PatB)
