60 standard - questions
red with envy
10-26-2007 12:52:34
Howdy, I just became the owner of a 1954 JD 60 std. I was wondering if someone knows the numbers of these made and/or the history of these tractors. Also, I am looking for a left battery cover for it as when it was being delivered the dang thing blew off. Thanks for any info provided.
Marc
josh long
10-27-2007 06:39:50
 Re: 60 standard - questions in reply to red with envy, 10-26-2007 12:52:34
I also have a 60 serial # 60000474, I think that is the right number of 0s, and was wondering on this particular one did it have the option of power steering or 3 point hitch? mine has an aftermarket power steering unit and I also have a factory power steering unit off of a later model. It does not have a three point hitch, but I was thinking of trying to find one for it. which would be the better way to put it back together
DJD-Man
10-27-2007 05:39:17
Lowseat 60 STD Gas 1745- Allfuel 60 STD 196- High seat Gas 60 STD 676- High seat All fuel 60 STD 210- High seat LP 60 STD 25. Orchard 60 Gas 287- orchard all fuel 527 and LP Gas orchard 45. What is the serial number on it? Post some pics of the new addition. Think these are correct.
redwithenvy
10-27-2007 09:49:23
 Re: 60 standard - questions in reply to DJD-Man, 10-27-2007 05:39:17
third party image
Howdy and thanks to the folks with all the great info. I still need some leads on where to get a left side battery cover for her (either new or reproduction). The serial number is 6027979 and hopefully.. here is a pic if I get this right.
redwithenvy
10-28-2007 08:40:39
 Re: 60 standard - questions in reply to redwithenvy, 10-27-2007 09:49:23
Home is now in a little town of Estacada, Oregon. I came across it about an hour and a half south of me. It needs some cosmetics but "runs like a deere". Wheels are calcium rotted, so I need to find some new or used ones. Do not know if that is an easy task or not. Any ideas?
DJD-Man
10-28-2007 17:19:48
 Re: 60 standard - questions in reply to redwithenvy, 10-28-2007 08:40:39
Hey great. Involve yourself in a tractor club out there and ask around about tires and rims. Should be easy enough. There is a place called trusty tractor in Oregon. Between joining a club, some phone calling, and the resources here, you will get along. Have a seat belt on when getting parts, they are expensive. Do you have a dealer nearby? Good luck.
DJD-Man
10-28-2007 05:22:18
Redwithenvy- Nice addition to that red barn. Appears to be low-seat 60. Serial 60250000-042999 were low seat. Great pic. What state is home now?
jd b puller
10-26-2007 17:13:15
There was a low seat standard, and a "high seat" standard. I've got something at home with production numbers in it, can look it up on Monday - maybe someone else can chime in in the meantime.
zwr
10-26-2007 18:38:41
 Re: 60 standard - questions in reply to jd b puller, 10-26-2007 17:13:15
I believe the older, "low seat" version of the 60S was a facelift of the AS and AO--same basic machine. Sometime in 1954 the model was updated to become basically a 60 Row Crop fitted with a low, wide front axle and smaller rear wheels.This was the hi-seat model, fhs seat/operator station became the same as the row crop 60. The battery box supported 2 6-V batteries, and the top of it supported the driver's seat cusion/.Somewhere near the rear axle there were probably changes made to accomodate the smaller rear wheel. I understand that there were only about 600 hi-seats made.
buickanddeere
10-27-2007 18:10:07
 Re: 60 standard - questions in reply to zwr, 10-26-2007 18:38:41
Rear wheels were larger on Standards. The 26",30" or 34" rim was required to keep the wider 16.9,18.4 & 23.1 width tires from getting too tall. The low seat 60 was a duplex carb & live pto upgrade from the AR which already had live hydraulics. The later AR's had a water pumps too if memory serves. The later high seat 60 added the pressurized rad and allowed the use of a rockshaft & three point hitch.
