Cleaning
CD C
10-26-2007 11:53:42
I just got my first tractor,a 1948 B, and was wondering if there is a secret formula you more seasoned folks use for cutting thru all the dirt, nests and grime to start the cleaning. Any help is appreciated. Thanks.
Chris
Mike M
10-26-2007 17:26:31
 Re: Cleaning in reply to CD C, 10-26-2007 11:53:42
The first thing I always did to any tractor before it went into my shop was to wash it off with a pressure washer. I have a hot water model by Hotsy and really like it.
johns48jdb
10-26-2007 16:32:14
i like to take an air hose and just blow as much loose stuff off as i can to start with. maybe pressure wash it just kinda quickly. after it drys spray it with kero, let that soak for 10 or 15 minutes and then spray it with super clean by castrol. from wal mart, in auto, in a purple jug. about 6 bucks. DO NOT USE THIS INSIDE AND DO NOT BREATH IT. it will take your breath away. if you leave this on new paint it will stain it and start to eat if off in 4 to 5 minutes or less. it may take a couple of applications of this but it works real well. go to johnnypopper.com and under the potbellied stove section there is a dicusion going on right now about f.i.t"s lye gravy. i"ve heard it really works. also there has been in the past about using electrolysis to clean parts. i don"t remember if f.i.t is the same one who does that. its just like this wonderful site. you can get all the help you need if you just ask nice. people on both of these sites are great to learn from.
Mike n Mo
10-26-2007 15:45:00
What I've done in the past with reasonably good results is use oven cleaner, and then loaded the tractor on a trailer and went to the local car wash. Spent 8-10 dollars, but well worth it. Mike
ET
10-26-2007 12:56:07
A putty knife is the first stage. Then degreaser and a hose or preasure washer. You will never get it all until you take thinks apart.
patsdeere
10-26-2007 12:26:28
I would have to agree. A pressure washer is great. A hot water one would be even better, but anything is better than nothing. For the gooey areas I like oven cleaner. It goes on foamy and cuts the grease pretty well. It might take a few times, but eventually it will go. For the real thick goop I use a putty knife or a screw driver.
Good luck.
Don't forget the elbow grease (you will need it).
memory4
10-26-2007 12:24:32
ive had good luck using oven cleaner
RobMD
10-26-2007 12:11:31
pressure washer.
If you don't really want to buy one, use a putty knife and scrape away at it using kerosene to make the crud softer. Seriously, that's about all you can do.
