4300 loader
jdman(MO)
10-25-2007 19:01:30
Just got a 4300 with a 300x JD loader, The dealer hooked it up to the rear remotes, and used an aftermarket control valve. To use the loader you must bungee the tractor control. O course when you do this the 3 point is disabled.The tractor had no built in joystick. Is there a way to hook up this control box without going through the rear scvs. Russ
RobMD
10-26-2007 16:49:41
 Re: 4300 loader in reply to jdman(MO), 10-25-2007 19:01:30
shouldn't have bought it like that. You will now have to have the correct hydraulic splitter box that allows for power beyond the scv.
These boxes that allow for split separate hydraulics are around 450 500 bucks.
J Plunkett
10-26-2007 15:32:27
If you can live with that control valve have them put a power beyond kit on it to power loader off of.Everything else will work as it should or just have them put the joy stick control valve on like most of them have.
Mike M
10-26-2007 10:06:17
Sounds like your dealer doesn't know what they are doing ! I'd settle for no less than the proper factory loader control valve.
