Help, more 520 questions
Eldon (WA)
10-25-2007 16:48:38
I am trying to get the fuel shutoff assembly off the gas tank but the governor arm is in the way. Looks like the tank has to come off or loose anyway....ya gotta be kidding me!
I took the 8 bolts out of the hood and it won't budge....does the front radiator shroud and plate under the tank have to come off too??? Choke rod and steering shaft?? Please tell me there is an easier way!
machinery-man
10-26-2007 10:28:37
 Re: Help, more 520 questions in reply to Eldon (WA), 10-25-2007 16:48:38
Your doing brain surgery on a tooth ache. Take the bale off the unit as well as the sediment buld. All lines loose and the unit will rotate off. Be sure to use some good sealer in putting in back on or you'll have a leak at the tank.
Eldon (WA)
10-25-2007 19:29:17
OK,a JD buddy just happened to stop by to see the new purchase and he showed me that taking all the fittings off and unhooking the rod from the carb gave just enough room to spin the assembly off....no need to remove gas tank after all, but still a pita for a sediment bowl!
Mike M
10-25-2007 18:44:14
Welcome to the world of 2 cyl. repairs ! They sure do require "special" handling not needed on a more conventional designed tractor.
SMinWi
10-25-2007 18:07:24
You need to take the grille off first. The radiator shroud does not need to be taken off. After you got the grille off, you will find two bolts on each side of the radiatoe top tank that hald the hood on. The steering shaft will need to be removed.
