2020 powersteering problems
Zakk Rankin
10-25-2007 13:45:30
I have a 1968 model John Deere 2020 and the steering colum keeps blowing the top seal. i have put a completely new seal kit in the column, but after about two hours in the feild it blew the same seal, and started to pour hydraulic oil out of the column. Also, once it gets hot, to start it you have to put water on the fuel pump to get it to start, what could be the cause of this?
jdemaris
10-25-2007 18:12:07
 Re: 2020 powersteering problems in reply to Zakk Rankin, 10-25-2007 13:45:30
In regard to the starting - is your tractor cranking slow when hot - or cranking normally and just not starting?
I ask because slow cranking will cause problems even with a good injection pump.
If it is cranking slower when hot - your steering is likely the problem. Get it cranking correctly before worrying about the injection pump. Try a $10 manual destroker.
In regard to what Bob mentioned - i.e. worn head & rotor - that's common. Many of the Humvees in Iraq right now - with basically the same pumps as your's - need to be dosed with cold water to get started after they're hot. They have a lot of premature pump-wear problems over there due to the high heat and thin JP8 military fuel.
Dumping cold water on a hot pump won't hurt it as long as the engine isn't running when you do it.
In regard to your steering - have you pulled the two steering valve cartridges all the way out - and checked the big o-rings inside? They are probably blown - and causing your leak and your starting problem.
K.W. in Tx
10-25-2007 16:45:18
The only thing I know is cold water or even warm to hot water should never be sprayed on a fuel pump. Its not good for the pump body Im told. But if it makes yours crank that is strange.
Bob
10-25-2007 16:53:08
 Re: 2020 powersteering problems in reply to K.W. in Tx, 10-25-2007 16:45:18
When the head and rotor wear in the injection pump, there is too much high pressure fuel leakage @ cranking speed for the pump to build enough pressure to "crack" the injectors, and inject fuel.
Pouring cold water on the pump (while the engine is stopped) shrinks thing up, and reduces the running clearance enough so the internal leakage is less, and it will start.
I've known guys to do this for YEARS, 'til they could afford to fix the IP, with NO ill effects,
What you NEVER want to do is hit the IP on a RUNNING engine with cold water. There's a POSSIBILITY the "head" will shrink so quickly the rotor will seize to it, breaking the pump driveshaft, or shelling out the timing gears.
K.W. in Tx
10-25-2007 16:47:39
I forgot mention you should only put water on a pump when it is cold.
