3020 hydraulics problem
Rick Niemeyer
10-25-2007 13:20:31
I'm still having problems with no power steering, no lift and no brakes on my 3020 with sycro-range Xmission. I have replaced the filter, cleaned the steel screen, checked the control valve on the pump under the front of the tractor under the radiator. I ran the tractor to for a while - still no power steering. Stopped it and pulled the new filter and there was no fluid in the filter or filter housing. I guess the next try will be the transmission pump??
If so, how do I get to it? Is it near where the filter is located? I had checked the valve next to the filter (bypass valve I believe) it was free to move and seemed ok.???
Any more thoughts out there for me??
Since I have no fluid in the filter housing, does that rule out the hydraulic pump at the front of the tractor?
ET
10-26-2007 09:46:38
 Re: 3020 hydraulics problem in reply to Rick Niemeyer, 10-25-2007 13:20:31
Pull the rockshaft. The pump is bolted to the rear of the top shaft. Probably time for a new pump.
Rick Niemeyer
01-11-2008 06:12:52
 Re: 3020 hydraulics problem in reply to ET, 10-26-2007 09:46:38
Yes Sir: That was the problem. Broken gear and sheered keys in trany pump. Replaced pump.
Thanks to you,
Rick
donmyeil
10-25-2007 13:53:25
Try this , remove the filter can,put a bucket under it and run the tractor with the clutch out, you should get abt 4 gpm at 1900. If you get no oil then the trans pump has a problem. you have to remove the rockshaft housing to get to it. Did this quit all at once? if the tractor was allowed to coast with the tractor in gear, and the clutch pedal held down, the clutch facing will blow off and not drive the pump. ( have had customers pack sileage and coast back off the pile )will tractor move in gear? And yes thats why you have no front pump hyd. as the trany pump supplies the front pump.
Rick Niemeyer
10-25-2007 18:11:35
 Re: 3020 hydraulics problem in reply to donmyeil, 10-25-2007 13:53:25
I removed the filter and ran the engine and no fluid. It was working fine when we parked it - steering ok and blade on back being able to lift and rotate fine. The tractor set for about a year and when cranked it up, it had no steering no lift and etc. I hear there is a key that may be seered on that pump. How can I test that? That sounds logical since I can run the engine at 1900 rpms and get no flow. Even if the pump was worn, I should get SOME flow at that rpms. What next? And THANKS so much for your reply.
donmyeil
10-28-2007 14:40:45
 Re: 3020 hydraulics problem in reply to Rick Niemeyer, 10-25-2007 18:11:35
Sorry I havent Got back sooner. The trans pump drives off the end of the trany top shaft. It has two drive lugs on the pump gear that engage the shaft. You will have to remove the rockshaft housing to get to it. Lift it with an overhead hoist and carefully go straight up with it. You will see a cam follower that runs along with the rockshaft that hangs down. You will see how it engages with the rockshaft valve linkage,make sure this goes back in place or the rockshaft wont work. the pump is there in front of you, with some pipes on the back. (remove the cap screws and the pump pulls off the shaft) look at these especially the larger one as they can crack from vibrating against the trany. case. Once the pump is off take out 2 more cap screws and the cover comes off and you will see the gears. the housing is most likely worn out with too much clearance around the gears. purchase a new complete pump and dont mess around trying to rebuild it. That should "get er done" hope this helps Don
Rick Niemeyer
10-29-2007 06:35:58
 Re: 3020 hydraulics problem in reply to donmyeil, 10-28-2007 14:40:45
Thanks for your reply - I do appreciate it.
It will take some time for me to do this task since the tractor is several miles away and I can only work on it in "spare" time. That sounds like a big job since I have limited access to a overhead lift. With that in mind, I will have to explore my options. Again Thanks for your help.
Rick
