Eliminating fuel cut-off solenoid
Kent in KC
10-25-2007 08:30:06
I have a '71 2020 with the electric fuel cut-off solenoid on the Marvel-Schebler TSX905 carb. It runs way too rich, black smoke out the stack, solenoid is not operating and looks like someone took the needle out of it.
I've heard a lot of guys replaced the solenoid with a manual needle valve. JD lists one (RE 19640) but it is quite a bit shorter than the solenoid and the threads don't reach far enough into the carb body to use it.
Does anyone have any idea where I might go to find such a part? I've restored this tractor and am anxious to get it out of the shop, just waiting on this last thing. Thanks for your help.
grwrench
10-26-2007 15:32:32
 Re: Eliminating fuel cut-off solenoid in reply to Kent in KC, 10-25-2007 08:30:06
part # for manual load valve is AT14476
buickanddeere
10-26-2007 08:05:52
Don't get by with a plain jet without the solenoid by setting the idle speed to fully close.And shutting the tractor off via the throttle lever. It's been tried by people who are now resting quietly. They lost brakes and power steering when the engine stalled.
grwrench
10-25-2007 15:52:08
hello, i"m a 40 year JD TECH. i"ve been using the manual adjuster from a 2010 carb.
Kent in KC
10-25-2007 18:56:17
 Re: Eliminating fuel cut-off solenoid in reply to grwrench, 10-25-2007 15:52:08
Hey grwrench, could you tell me that part number for the needle valve you use? Thanks!
matthies
10-25-2007 13:01:10
What is the part number of the solenoid you need? I'm thinking I have one at my brother's place that I acquired somewhere and never used. chris
Kent in KC
10-25-2007 14:23:23
 Re: Eliminating fuel cut-off solenoid in reply to matthies, 10-25-2007 13:01:10
Chris,
JD says the solenoid is a RE 19408 and the needle valve is a RE 19406, but the needle valve doesn't fit my carb so I'm doubtful the solenoid they list will either. My solenoid has a longer snout than the one they show in the parts diagram (although, admittedly it is only a diagram). I could maybe email you a picture of my solenoid if you wouldn't mind. What's your email addy? Mine is [email protected]
Gerald J.
10-25-2007 09:24:15
Cutting the needle off the cut-off solenoid should make it run rich because that's the high speed needle. I suppose you could try for a smaller high speed jet, but that's not going to be a Deere part.
Under working conditions without the cut-off solenoid it will probably diesel when worked hard.
There could well have been a couple different zenith carburetors and cut-off solenoids used on the 2020, I know there were several different zenith and the abominable M-S used on the 4020.
You could also lean the mixture by lowering the fuel level in the float bowl, and in the process make sure that the fload needle actually shuts off. A worn float needle and seat were what made my 4020 run with black exhaust.
Gerald J.
Bob
10-25-2007 08:51:40
Try emailing Zenith Fuel Systems, and see if they can help you, or refer you to aomeone who can. Please post back, and let us know what you find out.
