JD 400 Industrial
UKRMB
10-25-2007 06:41:46
How do you drain and or check the rear case oil on this unit. Also, does anyone know where to find the serial # on this tractor?
UKRMB
10-26-2007 17:45:48
 Re: JD 400 Industrial in reply to UKRMB, 10-25-2007 06:41:46
What type of filters and fluids should I use and change. I am just using it as a acreage unit. Also, how do you fill the pump. It sure makes alot of noise when cold and at low rpm.
Roy Suomi
10-25-2007 18:26:50
The rear/hydraulic oil is checked with a dipstick..The location is by your right heel as you sit in the seat..You will notice a small knurled knob sticking upright next to the floorboard..unscrew it and pull it out..The S.N. tag should be closeby..Aluminum stamped tag rivited to trans case..
