JD 40T dirty hydraulic system
J. Chantry
10-24-2007 20:04:13
Bought a 1953 model 40T. Has dual touchmatic system. The hydraulic return line was broken off next to shifter several years ago. I would imagine dirt, etc has gotten into the system. Should I do a complete teardown/cleaning of system OR replace line, fill system with diesel and flush system? Or other recommendations? Thanks
J. Chantry
10-25-2007 19:38:00
 Re: JD 40T dirty hydraulic system in reply to J. Chantry, 10-24-2007 20:04:13
Thanks for the suggestions! It will be a working tractor. I planned on complete teardown/inspection/repair of the pump. Previous owner used tractor for bushogging (drawbar type) and did not use three point. So I imagine pump ran dry a long time. I like the idea of a flush, fill and run, then drain through a fine strainer.
THANKS
Jason Mills
10-25-2007 05:29:33
The pump will definitely need attention if it has been run dry all this time. I would say you could probably rinse resevoir out. Take seat off and get a flashlight to inspect through fill hole in top of unit. Good luck with your project, Jason.
JDNPC
10-25-2007 04:09:03
here is a question to ask yourself first. is your tractor going to be working more than parading? if you want worry free operation and peace of mind,i would probably recommend a complete tear down. but here is a process to help you determine the extent of your repair. one particular way to see if there is dirt and debris in the housing, is to flush with kerosene and then refill with fluid. drain it and strain it and this should show you exactly how clean or unclean it is. do this after it reaches operating temp also. you need to find out the condition of the pump also. it could need a thorough cleaning if it hasn't been circulating fluid for a while. i would start with an inspection of the complete hydraulic system and with the simple things first. i went through my t.o.m. about twoor three years ago, it wasn't much fun, but it was well worth the investment of time and money for trouble free operation.
