JD Aoil Filter
JimB
10-24-2007 17:00:34
When changing the Oil Filter on on JD "A" does the liner @ the outside of the Filter come out?
The Service Manual describs a Tool that you can build what is this tool?
hardscrabble
10-24-2007 17:45:46
 Re: JD Aoil Filter in reply to JimB, 10-24-2007 17:00:34
NO!!! That is your filter housing, and needs to be removed only if damaged(crushed from overtightening). The tool decsribed in your book is for installing a new housing.
P Browning
10-24-2007 17:42:33
 Re: JD A oil Filter in reply to JimB, 10-24-2007 17:00:34
Jim -- Only the filter should be removed in this is a routine oil & filter change. Be sure also to renew the o-ring, and do not tighten any more than just enough to bring the cover up snugly.
You don't need a service manual to tell you what to do when performing routine oil & filter change. Consult your Operator's Manual for more details. And if you don't have one, I recommend you let someone know that it would be a nice stocking stuffer! Call (800) 522-7448 with model & serial number in hand along with your credit card.
To determine jsut which Deere publicatins go with your tractor, go to the JD-H Restoration site (below), scan across to ARTICLES 1, and the of the drop-downs, select DEERE PUBS. On page 2 of that piece you will find the manuals for your particular tractor, and on page one are instructions for obtaining them.(PatB)
