520 gas in oil problem
Eldon (WA)
10-24-2007 15:09:37
I just bought a 520 for my wife and got it home a couple of days ago. Today I went to start it and it blew oil/gas out the breather tube. I drained the oil and got about 4 gallons of gas/oil out of the crankcase. No gas left in the tank. Is this a common problem? What's causing this? Thanks for the help.
machinery-man
10-25-2007 13:47:09
 Re: 520 gas in oil problem in reply to Eldon (WA), 10-24-2007 15:09:37
the heart of the matter is where the special o ring meets the body and pin. I always take a file and smooth the bottom of the body. A small c snap ring holds the item in place. One thing is to mark top and bottom of the plates as well as the postion before tear down. I"ve found that the floats/needle never would completely hold fuel especially the rubber tipped ones.
SWD
10-24-2007 19:35:39
I have a B, is it possible my fuel shut off isn"t working? I found gas in the oil.
John T
10-25-2007 07:02:50
 Re: 520 gas in oil problem in reply to SWD, 10-24-2007 19:35:39
Yours dont have the auto shut off so if youre gettin a lot of gas in the oil its more likely your carbs needle n seat assembly and/or float has a problem. Its best to always shut the gas off at the sediment bowl (or any other shut offs it may have) on those tractors when theyre sittin
John T
John T PS
10-24-2007 17:41:23
We talked about the same thing a few posts down below. Id also cast another vore for a leaky rubber diaphram in the auto shut off sediment bowl. Yeppers if you remove the lil oil lines there shoud be oil ONLY no gas. If its NOT the problem then Id be thinkin a bad carb float/needle valve buttttt ttt that means BOTH the carb PLUS the sediment bowl shut off have problems for gas to keep runnin into the oil sooooo Im stickin to the diaphrams is the problem fer now lol..... .
Yep JD has the new diaphrams and I replace the lil o ring/washer on top the vertical shut off plunger when Im in there.
John T
RobMD
10-24-2007 15:29:21
It's a common problem for ANY old tractor.
What is happening is that your fuel shut-off is not working AND your needle valve in the carb is stuck open, thanks to a gummed up float. This allows fuel to bypass the shut off, fill up the carb bowl, bypass the needle valve, and dump in the cylinders. You've got to repair the shut off and the carb before it happens again.
Kurt_JDB
10-24-2007 17:06:28
 Re: 520 gas in oil problem in reply to RobMD, 10-24-2007 15:29:21
I think the 520 has a shutoff that works by a diaphragm and oil pressure. I understand that if the diaphragm leaks, then gas can actually enter the engine from the oil line. So it could be that his carb is OK.
Kurt
Eldon (WA)
10-24-2007 17:14:06
 Re: 520 gas in oil problem in reply to Kurt_JDB, 10-24-2007 17:06:28
Thanks.....I guess the two small lines coming off of the sediment bowl are oil pressure lines that open a valve when pressurized? I will disconnect them and put some gas in the tank and see if it comes out there or drains into the crankcase. Do they make a sediment bowl diaphram repair kit?
RobMD
10-24-2007 20:32:26
 Re: 520 gas in oil problem in reply to Eldon (WA), 10-24-2007 17:14:06
you can get the two diaphragms, that's basically all you need, and the little o-ring that goes on the end of the push down nut thing. all you'd have to do then is to clean up the aluminum = glasss with some carb cleaner and get a new strainer and gasket. looks real nice when done all up.
Hey, that's a good idea about checking to see if its the diaphragms! learn something every day!
Eldon (WA)
10-24-2007 21:23:43
 Re: 520 gas in oil problem in reply to RobMD, 10-24-2007 20:32:26
OK.....I've been all over the web and can't find repairs....all I see are the plain old overpriced sediment bowls for these tractors. Who sells the repair parts???
Iten
10-25-2007 07:38:57
 Re: 520 gas in oil problem in reply to Eldon (WA), 10-24-2007 21:23:43
I just rebuilt my 520 fuel bowl assembly. Most of those part are cheap <$3.00 from Deere. If you need an entire assembly it is very expensive from Deere $250.00.
Eldon (WA)
10-25-2007 12:48:21
 Re: 520 gas in oil problem in reply to Iten, 10-25-2007 07:38:57
Yeah I called the local lawn and garden Deere and they said $3.50 ea for the diaphrams, $3 for fuel screen and $3 for the bowl seal...should be in tomorrow.
John T
10-25-2007 06:58:59
I got mine (diaphrams and o ring) direct from the local Mother Deere shop.
John T
