520 PTO knocking
Kerry Roberts
10-23-2007 20:46:26
When using my JD 37 pull-behind sickle mower with my 520, I noticed the 520 developing a knocking noise under my right foot when turning with the mower (which applies side thrust to the PTO shaft). It sounded like a bearing going out.
With only a couple of acres remaining I continued to mow, but disengaged the PTO when making turns. Then I noticed that the PTO clutch wouldn"t stay engaged unless I kept my foot on the PTO clutch pedal.
Before I start taking things apart I"m wondering if anyone else has had this problem and can give me an idea of where to start.
I"ve never had the PTO apart. Thanks in advance, Kerry
mjbrown
10-24-2007 07:05:15
 Re: 520 PTO knocking in reply to Kerry Roberts, 10-23-2007 20:46:26
With pull behind pto driven implements the pivot point where it is hooked to the drawbar needs to be about half way between the pto ends. Try lengthening or shortening your drawbar and see if it helps eliminate the noise. The noise is coming from the pto shaft on the mower not the tractor.
Ben.So.Tex
10-24-2007 04:59:39
My 50 does the same thing with a drag type sherred behind it. But only when I am turning. I think if you check the archives you may fine some info on it. My 50 has live PTO.
You may want to adjust the pto so it has a snap, Check your operator manul for proper adjustment.
machinery-man
10-24-2007 04:54:19
Don't take anything apart, your noise is normal with mower, as you turned the pto joint angle throws a load on the shaft telegraphing the noise on into tractor. This is normal. I always run my tractor at high rpm to offset the torque of the flywheel, mower stroke. As to the petal staying in you need to tighten your pto clutch. Real simple to do, have to remove three point and right elephant ear...remove inspection plug, screw the lock screw in then tighten, back off lock screw(get a manual for better procedute), but DON"T tear into PTO over the sound.
