John Deere M with a stuck motor
Bill Dunlap
10-23-2007 19:51:25
I just bought an M with a stuck motor. I bought a Farmall 450 gas 3 years ago with a stuck motor also and got it free with some tranny fluid soaking on the stuck pistons and some wood and sledge hammers. I put some tranny fluid on the pistons of the M and it has soaked a few days and I am about to love tap on the pistons but was wondering if you guys had any other secrets. The inside of the motor looks really good and I don"t want to rebuild it right now I just want to free it and get it running for now.
wkk427
10-25-2007 20:06:07
 Re: John Deere M with a stuck motor in reply to Bill Dunlap, 10-23-2007 19:51:25
keep soaking and jack the back end up on one side.put tractor in gear and start rocking back wheel back and forth every day.after about a week you should start to see fan start moving.be patient
M Nut
10-25-2007 08:41:40
I took the starter off on a 47 M and used a pry bar to apply pressure to the ring gear. It poped loose right away. It had soaked for about 2 weeks prior. Good Luck
n29we
10-24-2007 02:18:00
Earlier this year I bought a 47 M with a stuck motor also. It had not run since 1976. The big factor in freeing mine up was that it had an orchard exhaust thus no direct water was able to get into the engine. 6 days of a PB Blaster Marvel Mystery oil mix in the cylinders and it freed up and now runs perfectly. I had a JD crank that I was able to manually try the engine everyday until it loosened up, then I used the electic start to get her running. Good luck with yours!!! JimO
