1010 rock shaft settings
lonzo
10-23-2007 19:09:01
This 1010 came in the shop with 3 point not working, i found a pin had fallen out inside that holds the linkage, the rockshaft started working but it would hunt, i then replaced piston seals and the 2 end plate seals and still it would hunt, this rockshaft has 2 piston set up with one soloid rockshaft, not the kind where you bolt the arms together.It also has one control lever, it does have 2 control shafts and the out side or hollow one is used while the center one is locked with a spline plate that is spring pined so it won't twist. you can rotate eather the out side shaft or the inside shaft and the rockshaft will work. where do you set the locked control shaft? I have looked threw the IT manual and all i see is dual control set up or single contol shaft set up, Never have i seen a dual piston set up with a solid rocksaft and 2 shafts (one inside the other) and only use one shaft to control the 3 point, and the inside shaft locked but it will work when you remove the spring pins and rotate the inter shaft I havn't any idea why this thing is made this way, i can understand single or double piston rockshafts but not this hybrid, any help you can give will be appreciated..I hope i have made sence of this thing.
