Good, Bad Ugly of JD 3010
ShepFL
10-23-2007 14:11:32
At our county fair older gent came to wanting to sell his 3010 Dsl. I know nothing of JDs so looking for inspection points and avg costs.
Thanks!
R. John Johnson
10-24-2007 05:43:57
 Re: Good, Bad Ugly of JD 3010 in reply to ShepFL, 10-23-2007 14:11:32
One more thing to check. Look at the weep holes on the left side of the block. Signs of antifreeze leaking hear mean seals between the sleeves and blocks are going and you will be inside the engine replacing said sleeves and seals (Minimum).
John
ET
10-24-2007 05:25:22
Look for oil leaks from the main pump over the front axel. See if the pto works the shifter pins are easy to break and a pain to fix. A common oil leak is out of the right rear corner of the head gasket. Look for leaking load shaft seals, thats under the drawbar frame.
rcola
10-23-2007 17:13:08
I learned to drive on a 3010. My dad still has it and last year I bought one at auction for $3,800. My wife drives it some and likes it better than my 4030 or the 6420. Drive it down a fairly steep hill trying all the gears 'cause some worn ones will want to jump out of some gears. You also may want to convert to a 12volt system. Robert
Dandeere
10-23-2007 16:57:59
Hi ShepFL, the 3010 is the new deere in my heard; it is like driving Caddy compared to the old bucks!! I would check sloppy shifter,shifting on the go if syncro.trans.(you should be able to get in reverse when rolling forward in all the ranges),oil leaks by 3pt draft shaft, and sound&leaks of hydro. pump. Also make sure pto shifts 540 to 1000 rpm, and usual overall wear and tear. That is my short list for ya. Costs I can not help ya with, I bot mine in 1985. Dan
Gerald J.
10-23-2007 17:36:47
 Re: Good, Bad Ugly of JD 3010 in reply to Dandeere, 10-23-2007 16:57:59
When you check the PTO speed shift be sure you know how to do it correctly, because its easy to force and break it.
Gerald J.
msb
10-23-2007 16:40:27
I remember the first 3010 I drove. Thought I had died and gone to heaven.Attended several service schools that pertained to the 10 series back in those days.I can think of nothing to check on a 3010 that you wouldn't check on any used tractor.Just drive it and put it through its paces in all gears.Listen to her run and look for any leaks. Only complaint is I think they could have used a little more horsepower for their size like the 3020 had.If the tractor has been overhauled it should now have the 20 series pistons and sleeves ,so it should be comparable in horsepower to a 3020,if the pump was turned up to 3020 specs. Brakes on a 3010 will tend to chatter or grab, but the steering is easier on a 3010 than a 3020.Pretty much a trouble free tractor in its day. Very few ever came back through the shop.
JMS/.MN
10-23-2007 15:29:40
I've had 3020, 4020, several other newer JD- all Power Shift transmissions. 3010 will have s Synchro transmission- I never will. Just a personal thing- drive it and see how you get along with it. Otherwise- you can update them for more hp, etc. You're dealing with a tractor from the early 60s.
