50 starting problem
wikevin
10-23-2007 10:10:00
Howdy and thanks in advance for any and all help:
Was using the 50 the other day when it quit. Thought it was out of fuel but no Im half full. I push the starter and it pops right off and it starts I let go of the starter pedal and it dies instantly as if I had hit the kill switch. My 50 is a late model if that helps. Also the light wont come on with the switch unless Im also pushing the starter pedal. Thought Id see if anybody had this trouble before I start the search for my 2 cyl electrical manual and start following the schematics. Thanks Kevin
almrm
10-24-2007 12:22:38
 Re: 50 starting problem in reply to wikevin, 10-23-2007 10:10:00
I offer one more place to check. If the power for the switch is coming from the starter hot terminal, you may be getting a short from the starter rod action via worn insulation on the wire. The wire may not be tucked into the clips along with the heavy starter wire and rubbing on the starter rod. This is a long shot compared the the fine advice below, but might merit a quick check behind the flywheel cover. If the switch power supply runs all the way back to the battery, of coarse this is no help.
Good Luck,
Mark
CLW
10-24-2007 10:29:44
If it is still wired as it was from the factory you can run a jumper wire from the - battery post to the - post on the coil and it should start and run as long as you leave the wire connected. That would let you get it back to the house if you need to. I agree with the others that it is an open resistor, or wire from resistor to the switch, or bad switch.
CLW
10-24-2007 10:10:41
If you need a wiring diagram e-mail me at clwebbfamily@sbcglobal and I will send you one. Need to know if it is gas or LP model.
machinery-man
10-24-2007 09:40:05
I would probably go with the burned ballast as suggested....
Green Relics
10-24-2007 05:03:53
I agree with John T, You have a burn't out external ballast. When starting the distributor receives 12 volts to help start. Once you let off the starter switch the ballast reduces the voltage to appox 6 volts to keep the points from burning out quickly. Replace the ballast and it should run correctly. John
wikevin
10-24-2007 06:47:12
 Re: 50 starting problem in reply to Green Relics, 10-24-2007 05:03:53
tHANKS GUYS,if not sooner, I should get some time to work on it this weekend. Thanks Kevin
John T
10-23-2007 11:40:25
That problem is one that can occur if the tractor is equipped with an external ignition ballast resistor (after switch and before coil) plus a working ballast by pass WHEN THE BALLAST OR ITS CIRCUITRY HAS BECOME BAD/OPEN. How it works is theres an extral lil side terminal on the starter switch which supplies hot batetry voltage up to the coil (or low/coil side of ballast) ONLY while the starter motor is cranking. If the starter is depressed theres still hot battery voltage to power the coil even if the ballast were bad open i.e. she can run so long as the starter switch is engaged but die soon as its released (sounds like what you described).
ID LOOK TO SEE IF IT HAS A BALLAST RESISTOR AND IF SO SEE IF IT OR ITS WIRING IS BAD OR OPEN OR BROKE ETC. The ballast (with wires removed) should measure around 1.5 to 1.85 ohms across its terminals but if its open its baddddd dd
Or place a voltmeter or 6/12 test lamp on the coils input (NOT to distributor) and turn on the ignition switch and there ought to be around 6 volts present. If no voltage there (and it is a ballast system) see if theres voltage over on the input (from switch not to coil) side of the ballast?? If voltage is there but NOT on its output (and no other wiring problems) sounds like a bad burned open ballast resistor.
If its NOT a ballast system, then see if theres hot battery voltage present to the switches BAT input terminal????? if the switch isnt getting any hot voltage (from ammeter or L on the VR) it cant power up the coil..... .
If theres voltage getting to the switches BAT input but NOT out its IGN terminal when ON, the the switch is bad.
SUMMARY
Bad/Open Ballast resistor orrrrr rrr no voltage to the switches BAT input terminal (from ammater or L terminal on VR) orrrrr rr a bad switch.
John T
machinery-man
10-23-2007 11:08:08
You've lost main power to the switch...probably bad wire...by cracking you get 12v from the starter to the coil but no power through the switch...check for bad switch or power to back side of the switch
