2030 new clutch problems
Parry Jones
10-23-2007 02:57:13
I was just asked by an elderly neighbor to look at his 1987 JD 2030 that his son just put a clutch assembly in. I did not take part in the installation so I can't answer specifics about what was done or not done. The old gentleman says the entire pressure plate and throw out bearing assembly was replaced. I did find the old one nearby and the plate between the fly wheel and pressure plate was missing all it's friction material on one side and was an entire assembly. The son is not available for comment.
Here's the problem. The tractor range selector on the left that has a Park position will not go into gear. It just grinds so I'm pretty sure the clutch is not releasing. I pulled the gear selector (right side) back out of the park position and not I cannot move it at all even to return it to it's former position.
I looked at the clutch pedal free play and it was fine. I removed the inspection covers on the left side of the bell housing and had the farmer's daughter depress the clutch pedal. It appears to be working the clutch fingers fine and completely disengaging the fingers when released. The engine runs and is not bound up. What could the problem be? I need help. I hope I don't have to resplit the tractor.
Timberoak 2119
10-23-2007 10:34:20
 Re: 2030 new clutch problems in reply to Parry Jones, 10-23-2007 02:57:13
Sounds to me like one of two things, 1. The clutch disk is installed backward, would require spliting to correct, or
2. When assembled the splines weren't lined up and they pulled it together, this warped the disk, would require spliting and a new disk be installed. David
ET
10-23-2007 09:10:40
Those clutches are ajusted through the window by setting the first finger acording to the manuel then having the throw out bearing set against that finger and finaly bringing the other two fingers out to just touch the throw out bearing. You need a sevice manuel for the particulars. It would be easy to reajust from the outside. A seized pilot bearing would cause it to grind and not shift. Did it get replaced along with the throw out bearing?
machinery-man
10-23-2007 08:31:39
An additional thought, what's got me baffled is the drive or transmission should release, it is the second stage that is more exacting an needs adjustment. Even if the first forks were off, if you have good contact with fingers the tractor should be stopping...this tells me the clutch is binding, I would even check and make sure of item he installed, proper thickness, type, parts numbers...you need to quiz him as to what he's done before proceeding...see invoices..even talk to parts man...I could see a possible mismatch especially if they were aftermarket....I do all this before I went any further...you can adjust clutch externally and you should be able to see internal parts as the inspection ports are rather large. There should possible be an inspection cover at bottom....
machinery-man
10-23-2007 08:10:26
You"ve got a tough one, since you did not see the installation....I suppose he has installed the disc or discs in the right direction? All this is precision and after installation has to be adjusted properly. The two stage allows the tractor to stop while leaving the PTO engaged with additional depression of the clutch petal the PTO clutch releases. There is a special gauge tool, one can be made according to IT manuals for the proper adjustment. Not disengaging from the transmission is baffling me on your issue. You may very well have to split again if parts were inserted wrong, but better than damage to tractor.
Tx Jim
10-23-2007 04:51:09
 Re: 2030 new clutch problems in reply to Dontknow, 10-23-2007 02:57:13
What kind of clutch is it.single or dual stage? If dual stage find out if clutch fingers were adjusted with special tool. BTW no 2030's were built in '87 more like mid '70s. Tx Jim
msb
10-23-2007 08:09:48
 Re: 2030 new clutch problems in reply to Tx Jim, 10-23-2007 04:51:09
I agree with my buddy Tx Jim. If it was his first experince replacing a Deere clutch, he probably didn't know the clutch finger height needed to be adjusted and that it takes a special tool.
Parry Jones
10-23-2007 06:34:10
Don't really know the year, just going by what the old gentleman says. The clutch assembly has two disks in it. One between the flywheel and pressure plate and another between the front and rear pressure plates so I am assuming it is dual stage. The entire assembly was bought as such. I don't know if the pack comes preadjusted. How is that done if it does not come adjusted?
