2030 PTO
Wes Suksdorf
10-22-2007 18:23:13
I have a 2030 JD with an independent pto. My question is: How do I make the pto keep running? With the tractor on I engage the pto lever and the control lever between my gear shifts but as sson as I let go the pto stops. How do I fix this? The operators and IT manuals are very vague on this system.
Wes Suksdorf
Tx Jim
10-23-2007 05:05:45
 Re: 2030 PTO in reply to Bob Collins, 10-22-2007 18:23:13
If I remember correctly on each side of contrul valve is a small hex plug. Remove plug and a spring with a detent ball should be inside,check for broken springs and/or stuck balls. I have no manuals for 2030 so I hope my memory is correct. Tx Jim
