4020 Carburetor Electric Wire????
MCL
10-22-2007 11:00:40
Am putting a Marvel Schebler carb on a 4020. What is the electric wire for and what does it hook to?
Dave Sherburne NY
10-24-2007 18:55:10
 Re: 4020 Carburetor Electric Wire???? in reply to MCL, 10-22-2007 11:00:40
That wire goes to a Fuel Shutoff Solenoid. I had a
bad Solenoid on a JD 2520 once, and when I went to
JD for a replacement, he sold me an needle valve and
it did fit and work fine.
Gerald J.
10-22-2007 12:17:04
That wire hooks to a point hot with ignition on, not the coil though because its fed trough a resistor. Needs to be connected at the ignition switch and that depends on what version of the 4020 you have. There were at least three different sets of switches and wiring. Or pick up that switched 12 volts at the light switch, that's only on with ignition on.
Few people including Deere shops get the MS carburetor to run well. Back about 1971 there's a Deere SB that says when you can't tune it, get a Zenith. And Zeniths were also often equiped with the main jet shutoff solenoid.
Gerald J.
Mike M
10-22-2007 11:46:21
Don't even bother with that MS carb. go get a Zenith.
Kent in KC
10-22-2007 11:26:49
I think you're seeing a fuel cutoff solenoid. Its supoposed to shut off fuel when the key is turned off, so it won't 'diesel'. They were problematic and often replaced with a needle valve. I'm trying to find just such a valve for mine. The one JD sells doesn't fit.
Brianderry
10-22-2007 11:20:03
the wire on the carb is for it to sense gas and that is wat tells it to start sometimes u can get buy with out it and others u have to have it so u can try it.
Gerald J.
10-22-2007 12:12:37
 Re: 4020 Carburetor Electric Wire???? in reply to Brianderry, 10-22-2007 11:20:03
Bovine Scatology.
Gerald J.
wilamayb
10-22-2007 16:30:47
 Re: 4020 Carburetor Electric Wire???? in reply to Gerald J., 10-22-2007 12:12:37
Now that's funny
MCL
10-22-2007 11:27:44
What does it hook to?
