TDH in JD 510
atk_nut
10-21-2007 19:18:41
Any down sides to using TDH (Trans-Diff-Hydraulic) fluid in a 1969 510? What I am thinking is tossing the hydraulic tank and just running a deeper intake line into the rear end.
What do you think?
MSM
10-22-2007 00:13:18
 Re: TDH in JD 510 in reply to atk_nut, 10-21-2007 19:18:41
You can't run a "deeper intake line" in the rear end, it draws off the bottom now. I don't think you will have enough capacity in that application either,you are liable to run the trans too low,overfilling it is not an option as that will cause excessive foaming and heating of the fluid
