How do time a JD-B with electronic ignition
chas036
10-21-2007 12:42:08
I have a 1948 model B that has been converted to 12 volt and electronic ignition. I know that to time it with the points, you set the mark on the flywheel to the mark on the cover, and then you move the distributor until the number 1 plug sparks. With electronic ignition, this is imposible, so how do you time it?
John T
10-21-2007 18:47:07
 Re: How do time a JD-B with electronic ignition in reply to chas036, 10-21-2007 12:42:08
If (piston at TDC) you first retard forward CW the distributor and turn on the ignition but then slowlyyyyy yyy backwards CCW advance it (same as with points) the plug should still fire (with many newer elec switches) right when the magnet (on rotor where high cam was) just passes by the pickup coil which replaces the opening of the points. That sets the static start timing and then the centrifugal advancd ought to advance the timing with more RPM if its working correct which a timing light would show.
John T
machinery-man
10-21-2007 13:18:56
I always used a light on 50/520/530. I think the B has a demple on the flywheel cover that line up with the crank on TDC. You want to time it at TDC at low rpm and then it should advance 20 degree at high idle.
Bob
10-21-2007 13:07:29
Is it a Pertronix ignition, which has a "Hall Effect" trigger???
If so, it will act just like points, and trigger and spark as you slowly turn the distributor housing back AGAINST the rotation of the rotor.
If it is some exotic ignition that uses a wire-wound trigger coil, it won't "trigger" like that, 'cause the motion is to slow.
My GUESS is, though, you have a Pertronix, and will have no trouble setting it like you would points.
chas036
10-21-2007 13:15:26
 Re: How do time a JD-B with electronic ignition in reply to Bob, 10-21-2007 13:07:29
Can i use a timing light to set the timing well it is running?
Bob
10-21-2007 13:22:57
 Re: How do time a JD-B with electronic ignition in reply to chas036, 10-21-2007 13:15:26
Yes.
It's IMPORTANT that the advance be in good working order, though.
If you set it at 20 degrees at high idle, it needs to retard to close to TDC for starting, or it will "kick" and break the starter. (Human OR electric!)
