'48 A John Deere power trol question
GeorgiaHayFarmer
10-20-2007 16:45:11
Howdy,
On my power trol I have two quick disconnects coming off the side with 90* fittings. How can I use these? Why are they on the side with dummy plugs in the back? Is it because they don't have to remove and reinstall the dummy plugs with hydraulic plugs? It seems as if I read in the manual this could be done somehow. Ya follow me...?
Scott
Len Bull in NC
10-23-2007 07:25:15
 Re: '48 A John Deere power trol question in reply to GeorgiaHayFarmer, 10-20-2007 16:45:11
This connection on my A may be what you are talking about? It is an easy quick-connect for the 45 Loader. The connections come out of the two ports on the right side of the Powertrol case.
LEN
Link
Jason_VDB
10-20-2007 20:04:54
your system will work like this but not exactly how it should. if you really want to use the remote cylinder with your current system it would be best to look for the adjustable powertrol plug (assuming you have the newer powr trol system without the screw on collars) if you have the system like is on the numbered series deere made an "adjustable" plug for the top hole on your box. This plug looks similar to the normal dummy plugs but the cap will screw off and inside you will find a thumb screw. the thumb screw turned all the way in will act as the dummy plug and if screwed to the outer position it will allow oil to more appropriately bypass that plug and go into the cylinder outlets (your 90 degree elbows). I"m not entirely sure why all this works the way it does but this is how it works the best.
you only need one of these "adjustable" plugs. put it in the top hole and put a regular dummy in the bottom hole.
one other thing to remember is that (not seeing your system) if you want true breakaway couplers there needs to be hydraulic hose run from the 90 degree turns to the couplers and the couplers should be bolted to the tractor using the standard breakaway coupler bracket.
i have a "48 A as well with the exact setup that I described including a yakima hitch. its a cinch to use. finish plowing with the yakima plow. unhook adjust the adjustable plug for cylinder use, hook up to the wheel disk and i can be back in the field immediately.
if you don"t use the adjustable plug disconnect the cylinder if using the rockshaft. if using the cylinder and no adjustable plug the system is slow acting because as oil goes into the cylinder it will also go into the rockshaft system and the pump just can"t keep up with the oil demands. never seemed to hurt anything when i did it but it took a while to get the trailer plow out of the ground at the end of a furrow
johns48jdb
10-20-2007 19:16:15
i don't know what 90* means. is it 90 degree elbows? unless there is some trick that i don't know about you have to have the right plugs installed to convert the tractor from rockershaft to remote hydraulics. maybe i'm wrong.
