JD combine help needed URGENT
Alex-41JDb
10-20-2007 16:21:28
Can anyone tell me the length of the belt on a 6600 on the right hand side behind the main big pulley behind the tire up to the pulley that that drives the rpm meter. So from the little pulley behind the the big one up to the one that is attached to the one that drives the rpm. Girlfriends grandpa wants to cut beans before it rains mon and JD is closed tomorrow. thanks Alex
LarrySTN
10-20-2007 17:33:55
 Re: JD combine help needed URGENT in reply to Alex-41JDb, 10-20-2007 16:21:28
A-76 if the serial number is 100800 or below
A-70 if the serial number is 100801 or above
Alex-41JDb
10-20-2007 19:06:01
 Re: JD combine help needed URGENT in reply to LarrySTN, 10-20-2007 17:33:55
This isnt the little oring one but the one that drives the one that drives the one with the 2 connected by oring. There was some confusion when I asked this question on the tractor board. Is it still the ones you said, if it is please confirm. Thanks you sooo much. Alex
