46 B engine question
patsdeere
10-20-2007 12:05:52
I was just reattaching the rods and it seems difficult to turn the flywheel once they are attached. They are the same rods and number of shims so I would think that it would be fairly easy to turn. I did put new pistons and rings in, would this be the cause of the difficult piston sliding? If so, should I put a little oil in the cylinders to allow them to slide better or ???
Second when ever one piston gets almost to the top of the stroke the flywheel suddenly turns really well for about an inch or two and then back to the hard. Should it be doing this or is there something wrong that I don"t know about?
Thanks for the help.
patsdeere
10-21-2007 00:46:57
 Re: 46 B engine question in reply to patsdeere, 10-20-2007 12:05:52
I got it to work. Yippee. Thanks for all the help. It seems that some of the shims expanded (darn gremlins) and after a little rearranging they all decided to cooperate.
WeirdDeere
10-20-2007 18:52:17
Oiling the cylinders is an important step. I'm wondering, did you oil up the rod journals before assembling? You should do that too.
Brandon
johns48jdb
10-20-2007 16:33:52
i hate to ask at this stage in the game, but did you break the glaze on the cylinder walls before you put the pistons back in? if you didn't you need to stop what your doing and start asking for help before you go any futher. do you have a shop manual, a parts manual and an owners manual for your tractor yet. if not, order some now. have you taken your head to a machine shop to be checked and have the valves ground? have them resurface all the places anything else attaches.
patsdeere
10-20-2007 21:02:15
 Re: 46 B engine question in reply to johns48jdb, 10-20-2007 16:33:52
I do have all the books and don't remember reading anything about oiling cylinders before putting pistons back in. I have taken the head to the machine shop and had it completely (literally) redone. New guides, new valves, false seats, new springs, new keepers, new guide tubes, magna fluxed and a few other things. It looked new when I got it back. The cylinders had been honed so I figured there wasn't any glaze left on them.
P Browning
10-20-2007 14:21:14
Hey Pat -- Spray loads of oil into the bores. To be dry is not good here, or anywhere inside the engine. WD-40, STP Lube, anything you can get in there will help.
To go along with Mike's note, Below is an excerpt on shim adjustment by what is known as the TRIAL AND ERROR method -- from the JD-H Restoration Guide. Go slow, be deliberate, record what you do. (PatB)
TRIAL & ERROR METHOD -- During reassembly, adjust connecting rod bearings from 0.001 to 0.003 inch running clearance. Adjustment is by use of shims as connecting rods are attached to the crankshaft. Remove all the shims (one rod at a time) and measure the top and bottom stacks with a micrometer to ensure they are equal to start with. The thin shims are 0.003 inch thick. Install connecting rod with shim stacks and torque. If there is no binding or halting in crank rotation, remove 1 shim (top and bottom) and repeat until binding occurs. If there is binding, add 1 shim (top and bottom) and repeat. If it spins freely, you are good to go! ++++
Mike M
10-20-2007 13:21:09
You didn't oil the cyl. walls and the pistons and rings well prior to installing them ? You should also double check those rod bearing adjustments. If you loosen up the rod caps does it get easier to turn ????? If so you need more shims. To adjust the rods you remove one .003" shim from the top and bottom keeping the stacks equal.Then start tightening them up and if it gets so you can't turn the crank stop and add the shims back in. If you get them tight and crank still turns free. Go ahead and try removing one more .003" shim top and bottom and retry until they get tight then add a shim back in and it should be good. Have some oil or assembly lube on the crank journals too so you don't turn them over dry.
patsdeere
10-20-2007 21:04:04
 Re: 46 B engine question in reply to Mike M, 10-20-2007 13:21:09
I have loosened them significantly and it turns with some difficulty. When I tighten them snug then nothing moves. So I guess I do have a shim problem and a lack of oil in the cylinder problem.
patsdeere
10-20-2007 13:28:37
I didn't even think about oiling the cylinders before I put the pistons in. I guess I will try and get some oil on the cylinders and run them back and forth. I have tried loosening them and it doesn't appear to make any difference.
Thanks.
