JD 51 B Clutch fork?
Jeep65
10-20-2007 07:31:39
I just bought a 51 JD "B" that has been setting in a barn for about 20yrs. It is missing the clutch fork assy. In looking for one to put on this tractor I was wondering if the ones on the "A" or "G" would work or do i need one off of a "B"? If "B" only will work, what years will work?
Thanks
Don
jd b puller
10-20-2007 16:11:43
 Re: JD 51 B Clutch fork? in reply to Jeep65, 10-20-2007 07:31:39
I just sent you an e-mail...
Jeep65
10-20-2007 16:57:19
 Re: JD 51 B Clutch fork? in reply to jd b puller, 10-20-2007 16:11:43
I never got your email jd b puller!
Don
jd b puller
10-22-2007 05:06:56
 Re: JD 51 B Clutch fork? in reply to Jeep65, 10-20-2007 16:57:19
Seems like the e-mail function only works about 63.9% of the time...
I THINK I've got an extra one if you need it.
P Browning
10-20-2007 07:41:20
Slim to none is the chance for a fork from A or G to work!!
A clutch fork from B-96000-up will do the trick -- that's 1941-up. (PatB)
Kurt_JDB
10-20-2007 12:01:32
 Re: JD 51 B Clutch fork? in reply to P Browning, 10-20-2007 07:41:20
The parts in the assembly are all the same for 96000 on up except for the pulley brake. 96000-200999 is a AB2762R. 201000 on up is a AB3474R. Don"t know what the "actual" difference is. This info is out of the parts book.
Most of the assemblies are very worn out. The bearing housing and the fork shaft wear against each other, and this will result in a lot of play in the clutch leaver.
Mike Williams is the name of a machinist who rebuilds these assemblies. May be able to get one from him without a core.
Kurt
Jeep65
10-20-2007 07:54:25
Thanks PatB, will see what I can find
Don
