GEAR SHIFT LEVER
BOB MAZZA
10-20-2007 04:17:40
ANYONE KNOW WHERE Ican get a gear shift lever for a john deere model b tractor mine stuck in gear kicked it it broke off am told not to weld it thanks BOB
BOB MAZZA
10-25-2007 14:34:41
 Re: GEAR SHIFT LEVER in reply to BOB MAZZA, 10-20-2007 04:17:40
STILL LOOKING FOR GEAR SHIFT LEVER FOR JOHN DEERE MODEL B BENN TOLD IT IS PART NO B2582R,SURE COULD USE HELP, BOB MAZZA
P Browning
10-20-2007 05:04:11
Bob -- One thing for sure, just any old "B" gear shift lever may not be what you want. You will need to provide more specific data like serial number along with model number; a part number is even better.
Try some of these guys for starters - -
Detwiler's (715) 659-4252
Shephard's (715) 265-4988 Marlin Smith (712) 489-2570
(PatB)
BOB MAZZA
10-20-2007 09:41:35
 Re: GEAR SHIFT LEVER in reply to P Browning, 10-20-2007 05:04:11
CAN NOT READ SER. NO BOUGHT AS A 1950 JD B 6 SPEED, BOB
P Browning
10-20-2007 09:54:16
 Re: GEAR SHIFT LEVER in reply to BOB MAZZA, 10-20-2007 09:41:35
Bob -- do you have the PC330 Parts Catalog? Without it, you will be lost! See your local JD Ag dealer.
Is your tractor one of the with pressed steel side frames and a battery under the seat arrangement? If so, you have a tractor with serial number of 201,000 or higher. Before these tractors, the seat was the pan type.
B-201,000 was produced durng the 1947 tractor production year.
For B tractors, 201,000-up -- the gear shift lever is part number B2582R. 'Hope this helps. For more informatin, you are encouraged to shoot me an email which I can respond to later. (PatB)
