50 radiator core
deereford
10-19-2007 07:27:27
There are several choices and prices of replacement radiator cores for my 50. A & I, and several other sources, list one with the same number of core rows but with less total cores. Does anyone out there have any advise for me before I purchase one? Thank you very much for your input. I appreciate it very much! deereford
Kevin Meier
10-19-2007 14:41:49
 Re: 50 radiator core in reply to deereford, 10-19-2007 07:27:27
have you tried www.apairinc.com email or call nick all of his info is on the website. He may be able to help you out.
Good Luck Kevin
Mike M
10-19-2007 10:15:34
The new radiators don't match up to the old ones. Old ones had larger tubes. You have a water pump so any listed may work out ? I have in the past always took my core to the local radiator shop and got one. They would always have extra rows of tubes added so you ended up around the same total thickness but with more rows of tubes. Another thing they did was to add extra solder on the ends and make it thicker and stronger. This is usually the first area to go is it cracks around the tubes at the corners and leaks. I ordered one once from somewhere and was disappointed and sent it back and then went back to my local shop. I pay more but I get more too.
