John Deere 3020 block heater
BBoyette
10-19-2007 04:48:31
I want to put a block heater on my early model 3020 diesel. I was wondering how to plumb it in. It looks like connecting to the water return line from the oil cooler would be the simplest, but I don"t know how effective that would be. Thanks in advance for any suggestions. Bill
BBoyette
10-22-2007 04:45:08
 Re: John Deere 3020 block heater in reply to BBoyette, 10-19-2007 04:48:31
Thanks for the tips. I will give it a try.
Bill
msb
10-19-2007 07:24:58
I would use one of the hex plugs in the head and the drain plug.Deere has fittings for both. You may have to use some heat around the plug in the head to get it out.
Gerald J.
10-19-2007 10:30:30
 Re: John Deere 3020 block heater in reply to msb, 10-19-2007 07:24:58
That's what my 4020 parts book shows. Takes some care routing the hose from the left side to the right side below the water pump. I guess it works, I've not found a need for it yet.
Gerald J.
msb
10-19-2007 07:24:57
