1948 John Deere A clutch driver clocking
GeorgiaHayFarmer
10-18-2007 17:42:30
The right side of the crankshaft on my A does not have the arrow on it anymore for whatever reason so I need to find another way to clock the clutch driver in the correct position. Can anyone tell me what position the center of the weight is in with the #1 piston at top dead center? I believe I can position it correctly this way. Any other ideas are welcome.
Thank you,
Scott
Ben.So.Tex
10-19-2007 04:11:32
 Re: 1948 John Deere A clutch driver clocking in reply to GeorgiaHayFarmer, 10-18-2007 17:42:30
When you get it back in the right position take a chisel and mark it with a arrow so you will be able to fine it next time.
Earl - IL
10-18-2007 18:44:56
Looks like you might be getting some rain down your way.
GeorgiaHayFarmer
10-19-2007 05:02:48
 Re: 1948 John Deere A clutch driver clocking in reply to Earl - IL, 10-18-2007 18:44:56
Earl,
Woke up this morning to the sound of rain dripping in the gutters. We haven't heard that in a long time around here. They didn't think it was going to make it up this far into North GA. There is something to be said about the power of prayer.
Scott Griffith
Earl - IL
10-19-2007 19:37:59
 Re: 1948 John Deere A clutch driver clocking in reply to GeorgiaHayFarmer, 10-19-2007 05:02:48
Without water we are nothing.But I hope it gets dry enough so we can plow LOL Earl
Drew
10-18-2007 18:37:16
With the #1 piston @ TDC, the counterweight on the clutch driver should be @ the 3 o'clock position looking from the clutch side of the tractor.
F-I-T
10-19-2007 07:56:46
 Re: 1948 John Deere A clutch driver clocking in reply to Drew, 10-18-2007 18:37:16
Or, the counter weight of the clutch driver is 180* opposite of the flywheel counter weight.
GeorgiaHayFarmer
10-18-2007 18:42:21
Drew,
Thanks a lot for the helpful information. Now I can get on with the rest of the project.
Scott Griffith
