3020 Gas motor project
glsinNY
10-18-2007 16:33:47
I have a 1964 3020 gas in great shape, and runs pretty strong that has begun to seep coolant from the weep holes. Looks like a sleeve kit and a new set of bearings are in order.....any kind words of advice or insight to save me some headaches would be appreciated. I only want to do this once!!
Gerald J.
10-18-2007 16:56:35
 Re: 3020 Gas motor project in reply to glsinNY, 10-18-2007 16:33:47
At least sleeve seals. Might not be so much wear as old age. Might not be to the bearings yet. That was the purpose of the weep holes to get the coolant out before it went past the bottom o-ring into the oil to take the bearings.
But you have to decide on the repairs by measuring as you take it apart. You need a stock of plastigage for the bearings, and to look at the ridge at the tops of the sleeves. Cleaning the o-ring grooves in the block is important and they may be pitted to make more trouble getting the new o-rings to seal, so I hear.
Gerald J.
glsinNY
10-19-2007 15:05:08
 Re: 3020 Gas motor project in reply to Gerald J., 10-18-2007 16:56:35
Thanks for the input Gerald! I have heard about the pitting problem and getting the o rings to seal. I even heard of a situation where someone used JB weld to fill the pitting, then sanded it and they sealed right up. I hope it's just worn out O rings. The tractor was leaking oil from the rocker cover pretty bad when I aquired it. Obviously because of the oil leak all over the block, it was nearly impossible to notice the weep hole issues until I tore down everything but the engine, (good running, no smoke, no noises) cleaned painted and replaced a bunch of parts including radiator, water pump thermostat etc. put it back together and ran it for a couple of hours. I figure, it never had adequate pressure in the cooling system in a while, and that's what started the leaking thing.
