JD 3020 Hydraulics
Rick Niemeyer
10-18-2007 14:29:57
Need help. No power steering, brakes or lift. Have replaced filter, fluid and still no steering etc.
What next do I do?
Rick
ET
10-19-2007 06:16:30
 Re: JD 3020 Hydraulics in reply to Rick Niemeyer, 10-18-2007 14:29:57
Is a piece of dirt or crud holding the stroke control valve off its seat. Try putting in a manual destroking screw and screwing it down which will push the stroke controls valve wide open and maybe letting the crud pass through. You might have to just install a new stoke control valve which can be done on the tractor.
Rick Niemeyer
10-20-2007 12:24:37
 Re: JD 3020 Hydraulics in reply to ET, 10-19-2007 06:16:30
Sorry for the delay in my reply and thanks for your reply. I pulled the pressure control valve out and it was not stuck and it moved freely. As far as the stroke control valve, I have not touched it. I'm really not sure where it is located. Is it on the top of the hydraulic pump (one at the front of the tractor)? When I pull this valve, and reinstall it, should I tightened it down all the way or is there an adjustment to it? This one does not have a thumb screw to shut it off while cranking. Rick
ET
10-20-2007 18:03:31
 Re: JD 3020 Hydraulics in reply to Rick Niemeyer, 10-20-2007 12:24:37
About 15 bucks gets the destroking screw. It goes in the top of the pump in place of a plug. You can get at it easily.
LarrySTN
10-18-2007 21:02:14
Make sure the hydraulic pump is actually turning, as it is not uncommon for the drive coupling splines to wear out.
Rick Niemeyer
10-20-2007 12:27:18
 Re: JD 3020 Hydraulics in reply to LarrySTN, 10-18-2007 21:02:14
I have made sure the shaft on the pump is turning.
Thanks for your reply. I have pulled the pressure control valve to make sure it was not stuck and it all seemed free to move.
Rick
mike w J
10-18-2007 17:39:06
What transmision does it have? Is this tractor new to you or have you had it for awhile Powershift has a disconnect lever. on the left side of the dash.
Rick Niemeyer
10-25-2007 12:50:13
 Re: JD 3020 Hydraulics in reply to mike w J, 10-18-2007 17:39:06
I have the sycro-range transmission. I replaced the filter, and removed and cleaned the steel screen (it didn't seem least bit dirty.)
I ran the tractor for a little while, trying the steering and still no steering or lift. I then removed the filter again and there was no fluid in the filter housing. Sounds as if it's in the transmisssion pump. How do I get to that pump?
Rick
Rick Niemeyer
10-20-2007 12:30:23
Thanks Mike for replying. This tractor has been in the family for several years, and has been working great. It did sit for nearly a year though and when I cranked it up, there was no power steering.
Rick
chrisfromsolitude
10-18-2007 15:12:10
Check and make sure you have transmission pump pressure. Did you pull the sump screen out and check it while you had the fluid out?
Rick Niemeyer
10-20-2007 12:39:31
 Re: JD 3020 Hydraulics in reply to chrisfromsolitude, 10-18-2007 15:12:10
I pulled the screen when I drained the oil and it was clear of any trash. I don't really know how to check for pressure here. If I understand this correctly, there are two hydraulic pumps - one near where I pulled the filter and steel screen and one at the front of the tractor under the radiator.
How can I know which one is the problem. Does one supply pressure to other parts of the tractor or does the one at the transmission boost fluid to the front pump? This has a syncro-range transmission.
Thanks in advance for your help.
Rick
