JD 2040 starting issue
Chip Fontaine
10-18-2007 10:37:07
I have an early JD 2040 that I recently bought. It will not start unless you use eithier. It does not take much to start it but you would just run the battery down without it. I have been told it is due to low compression or could be an injector pump problem. Any ideas on how to determine which one is most likely the culprit?
Chip Fontaine
10-19-2007 04:09:19
 Re: JD 2040 starting issue in reply to Chip Fontaine, 10-18-2007 10:37:07
Thanks for all the great info.
To answer some of the questions: I bought the tractor for $1500.00 and as I said once it gets started it is smooth running and has a lot of features I don't have on my other two machines.(IH 424 and MF 50) It needs the either at any temperature. I put a new Bosh style starter on it soon after purchase. There was some talk of the machine being rebuilt shortly before the owner died. Perhapse as was suggested, the wrong pistons got installed. I will try some of the suggestions. Thanks again.
jdemaris
10-18-2007 16:11:25
At what temperature are you having the trouble - or won't it start on its own at any temp?
We sold the 40 series new and had more starting problems with them then any of new generation diesels before or after - especially the 2040s that were made in Germany.
I have to slightly disagree with a few comments by Mr. BuickDeere (I did say "slightly"). We had many occasions with two brand new 40 series tractors, parked side by side. One would start down to 20 degrees F with no heater or ether - and the other needed ether at 60 degrees F. And, as I said - these were brand new. Checked compression and both checked exactly the same. This happened many times. My point being - the compression reading won't necessarily tell you anything. But - obviously if its low - you've internal problems - or cranking speed problems. Many of the 40 series only got fixed with custom head gaskets and/or special pistons. So, there's a slight chance your's was rebuilt with the wrong pistons. In regard to the injection pump and testing? Maybe - but I have never known of any diesel pump shop willing do it. Half the cost of a pump rebuild is the time spent mounting the thing on a test stand - it's not a 10 minute job. And, most pump shops refuse to put any pump on their $10,000-$40,000 test-stand unless they've had it apart first. We did out own, regardless if Stanadyne or CAV - so we didn't need to use the test stand. The CAV pumps on 2040s had wear problems in the back of the pump with the transfer-pump fiber vanes. In regard to testing injectors - it's easy - but probably a waste of time if it's running okay once started. I've tested some really worn injectors out of tractors that started great in cold weather. If I was working on the tractor I would do the following. Make sure it's running good otherwise. If not - it's kind of moot looking for other problems. If - it only takes a whif of ether and it takes right off and runs wells - it probably has low fuel delivery at cranking speed and maybe retarded timing as well. This can be caused by a worn pump, or hydraulics slowing lugging the starter motor down, etc. You must get it cranking properly - before anything else. Install a $10 manual pump destroker if necessary. Once you feel it's cranking properly - and still doesn't start well. Try advancing the static timing by a few degrees - and - turn up the fuel delivery a little bit. I haven't heard the tractor start and run - so I'm guessing a bit. The 179 engines - as well as the 152s and 164s sometimes get shattered top piston rings. When that happens - they start awful and need ether even at 70 degrees F. And, once started will skip and smoke something awful until good and hot. Then, they will run fine.
buickanddeere
10-18-2007 17:25:07
 Re: JD 2040 starting issue in reply to jdemaris, 10-18-2007 16:11:25
I did miss asking what the voltage is on the starter while cranking. That is measured between the brass post going into the starter post and the starter's cast body. The larger 4kw starter from the Dubuque 414 cu" six will bolt onto the three and four cylinder Dubuques in place of the three kw unit. I put a destroker on my 1640, haven't got around to trying it yet however. The 1640,1840 & 2040 all used the same basic engine but varied the fuel delivery rate.
jdemaris
10-18-2007 17:55:58
 Re: JD 2040 starting issue in reply to buickanddeere, 10-18-2007 17:25:07
We had optional bigger starters available for the small engines - even back in the 70s. I'm talking about the Delcos - not gear-reduction NippoDensos, etc. The Delco was available in a 700 amp version and a 900 amp version. The 700 amp was IDed by the field-housing having a step-down on its diameter towards the rear, whereas the 900 amp starter was one diameter throughout.
We didn't use KW ratings back then - not here in the US - but as I recall the 700 amp starter is 3KW and the 900 amp is 3.7 KW.
buickanddeere
10-18-2007 19:07:24
 Re: JD 2040 starting issue in reply to jdemaris, 10-18-2007 17:55:58
The Bosch starters used on the German Mannheim were 3kw & 4kw units. They seem to like their metric over there.
buickanddeere
10-18-2007 15:20:00
Do an engine compression test. Take the pump and injectors to the shop for testing. Check the aircleaner. The engine may have drawn in dirty air and ruined the finished surfaces. Why did you purchase a tractor that only starts with an ether assist?
