JDNPC
10-18-2007 08:32:35
last week i thought i would upgrade to an electronic ignition for my 1950 mt. new coil, electronic ignition, wires, plugs cap, rotor, the whole deal. i'm not going to name the company i purchased it from because i haven't tried to retun the ignition yet.but here is the deal, after installing it all and running it for a week, by the way it ran great, but it shut off without warning one afternoon. spettered a few times when i tried it again, and nothing dead as a doornail. i'm not electrical whiz, but i can hold my own and i double and tripple checked all the connections, testlighted everywhere and even updated my system with a new 6volt battery. but to no avail, it sat for three days while i scratched my head. so, i took a wild notion to put it back to points. wow, after connecting everything and not even really adjusting the points to spec, it fired halfway through a rotation and purred like the day it left dubuque. never really did track down the underlying issue of why it didn't refire on the electonic ignition, and at this point i really don't care. but i have learned one valuable lesson. if it ran fine to begin when it was 100% factory green, DON'T MESS WITH IT. i suppose a true mechanical engineer or electrical one, for that matter, would have probably figured out the cause of the non-firing, but i figure that is the problem of the next fan of the electronic ignition conversion to figure out while his two cylinder is sitting in the field, and i'm out playing in the dirt with mine.
