A johnny's?
kirk in ks,
10-18-2007 08:00:14
will a late model A pull a little genius 3-16 on steel?
I know they have about 38 hp but when you get in gumbo ground , will it pull it even halfway in without bogging down?
Jason_VDB
10-20-2007 20:25:00
 Re: A johnny's? in reply to kirk in ks,, 10-18-2007 08:00:14
A regular off the line stock A without LPgas oversized pistons and LP manifold wouldn't in a lifetime want 3-16s behind it in gumbo. there is a huge draft difference between 3-14s and 3-16s. 16 inch bottoms should pull 8 inches deep 1 inch deeper than a 14" bottom and you are looking at 6 inches more width on top of that. In gumbo a 2-26 or 2-14 is all you should ask out of late styled A.
second if a plow ever pulls goofy and sideways and harder than a 3 bottom plow it means the plow needs to be adjusted to the tractor. Any plow that pulls sideways is either misadjusted or COMPLETELY worn out to the point that anyone could tell it didnt belong in the ground.
IH made a darn fine plow, far better than about any John Deere plow of the same vintage. I hate to say it because I do prefer to have matched tractor plow brands (purely for aesthetic reasons) but the deere plows especially the 2 bottoms were inferior to IH. the deere 3 bottoms were considerably better than their 2 bottoms.
if you want a nice plowing plow that buries trash and pulls decent go for an oliver later model plow with trash boards and hydraulic lift. but be warned you need an expert plow adjuster in the area to figure the thing out.
gtx1967jewison
10-21-2007 22:18:50
 Re: A johnny's? in reply to Jason_VDB, 10-20-2007 20:25:00
what about case plows of that era?
kirk in ks,
10-21-2007 07:38:37
well this plow is a little genius 3-16 on steel and ive got a mc cormick W-6, and i guess ill pull the 3-16 behind it if I ever get the plow cleaned up and the 6 redone so i can pull the plow with it,
I know the six will pull it as i think thats what it was desiged for,
the plow is all there and theres pics of it in the implement file, under mc cormick deering 3
-16,
and also the W-6, is on there too under the mainn heading of ih,farmall,
Jason_VDB
10-21-2007 10:04:18
 Re: A johnny's? in reply to kirk in ks,, 10-21-2007 07:38:37
I think you are right that would be a perfect plow for W-6. I think a No. 44 Deere 2-16 would be a good plow for your A although I"d look for a little genius 2-16 hydraulic plow. they are a little harder to find though. deere plows seem to be everywhere still
430WLPG
10-18-2007 18:30:16
It all depends where you are located. Around here a G would have trouble with 3-16's in this ground. My son has a 51 A and he pulled 3-14's with it, but it has 90 over Lpgas pistons and a Lpgas cold manifold and it was pulling hard and would not want to pull it that hard all day
Tom43
10-18-2007 09:09:20
Dear Kirk,
A John Deere A will not begin to pull such a large plow in gumbo. If you want to plow gumbo 2 14 inch plows will be plenty. We were able to pull 3 16 inch plows in gumbo with a new 3020 which was rated at 70 horse power.
Mike M
10-18-2007 08:15:13
A late A that is running right should work good with 3-16' Not sure about that model plow though ? My uncle used to cuss about that brand all the time. I hooked onto a 2 bottom of some brand at a tractor show once and it was all goofed up and wanted to pull sideways. Pulled really hard. I hooked onto another plow a 3 bottom and it pulled easier than the 2. I was pulling those 3 bottom behind a late B model in good conditions.
