JD 310a stuck between gears PLEASE HELP
wayne james
10-18-2007 06:38:05
I have a 1983 jd 310a and was working it and went to change gears i was changing both from high to low and also 4th to 3rd and it got stuck neither gear shift will move so its stuck between gears because the machine wont move! i was told to pull the top off the trans and that i could stick something in there and get it un stuck is this so? and if so if i pull it off will it mess up my brakes because its hooked on to the top of trans any thing i need to know about that? THANKS
Roy Suomi
10-18-2007 17:27:21
 Re: JD 310a stuck between gears PLEASE HELP in reply to wayne james, 10-18-2007 06:38:05
You might find a piece of shift linkage missing from the end of the shift shafts..The worst scenerio about the brake valve coming off is a gasket..You can support the brake valve with a bungee if you need to remove the shift lever plate to see whats going on in there . You won't have to bleed the brakes unless you take the brake lines loose..The shift shaft had a piece of fabricated steel to form a pocket for the shifter to engage the shift shaft..The ears have been known to break off so the shifter wont move in the other direction..This causes jamming in gear..I have been known to weld a piece of mild steel to the broken area..Beats splitting the machine to change out the shaft...
MSM
10-18-2007 09:45:23
You don't have to pull the trans top. Remove the floorboard and boots, the shift levers are held in with snap rings. Remove the snap rings,pull out the shift lever(s) and center the shift gates.A long screwdriver works well for this.Maybe raise one rear wheel with an outrigger to take the load off of the trans so it will shift easily.Once the gates are lined up,reinsert the shift levers and bolt on the removed parts. If the shifters jumped past the gates once,they will do it again,take it slow and easy on the shifting,or you will be splitting the tractor to replace the shift linkage.
