JD 4960 repower
Harry1265
10-17-2007 22:24:12
I am considering repowering a 1992 JD 4960 MFWD. Although i would love to repower this tractor with a modern powertech engine, i realize that it would be a logistical nightmare adapting the powertech engine to the frame, drivetrain, electrical system, etc to this series of tractor. I am also interested in increasing the HP of this tractor from 200 HP(PTO) to around 250 HP(PTO). I realize that dropping in another 466 engine would be the simplest solution if i can find one with the desired additional horsepower. Doing some research i discovered that the earliest JD 9600 Combines came with a 255 HP 466. Is the 9600 engine 255 PTO HP or 255 brake HP? I'm not even sure what the brake HP is on the stock 4960 engine. Has anyone out there repowered a 4960 with a higher horsepower JD 466 engine? A mechanic friend of mine (john deere schooled and employed) told me that the 15 speed powershift transmission in my tractor could probably handle an additional 75 HP without causing any harm to the tranny. I have known other people who just simply turn up the injector pumps on these tractors 10-20%, but I really don't care for that route, due to fuel consumption increases and decreased longevity of the engine. I would rather a 466 engine that was designed by JD to generate higher horsepower without hopping up the injector pump. Please help! Thanks
pennohio54
10-19-2007 00:49:54
 Re: JD 4960 repower in reply to Harry1265, 10-17-2007 22:24:12
as other posters have said,the 6076 will handle all the horsepower you want easily. they hold up well to high hp as long as their maintained. we have our 4455 tuned to 200 horse and it has handled it fine and its been set that way for over 3,000 hours now (has 8100 total). good luck
LarrySTN
10-18-2007 21:12:07
The current 466 in your 4960 will put out whatever horsepower you desire. We have a 4840 at 300+ for several seasons. We send in oil samples every oil change and haven't seen any increase in wear from when it was at the stock pump setting.
466HP
10-18-2007 20:47:46
Freshen the 466 that's in your 4960 with whatever it needs, set the injection pump for 260 hp, and quit worrying about it. It'll stand it. Trying to get 260 hp any other way, and you may as well trade tractors for the amount of money you'll spend.
Harry1265
10-18-2007 19:40:21
Thanks for the input:) I don't think i would really want to attempt swapping in new pistons from an 8000 series engine, altho i'm sure it would be feasible. I am curious to know what was done the 4955 to increase the HP that substantially. MSM, what modifications have you done to the 4960's that you own to make them turn increased HP? Different injector pump, injectors, turned up injection pump, different head, increased displacement or a combination of these or something else?
MSM
10-18-2007 23:24:41
 Re: JD 4960 repower in reply to Harry1265, 10-18-2007 19:40:21
It was all done in the injection pump by a local fuel injection shop,only other mod is the fan clutch is locked.
K.B.-826
10-18-2007 16:31:21
Getting 255 hp out of a factory 4960 engine is nothing. I know of a 4955 that ran 300+ for quite a few hours and is currently set at 240, and that's with the fan clutch locked up. Of course, it's had a few head gaskets put in.
skip33652
10-18-2007 05:21:29
put crank rods and pistons from a 8400 or 8410 in your block and turn your 466 into 496.
will it be that simple?probably not but it could be done.Paul
MSM
10-18-2007 02:23:23
Unless your engine suffered a catastrophic failure,rebuild it.It can be set to the same specs as the combine engine. It will affect fuel economy,more power>more fuel required.The only way to gain more power and not affect the fuel economy is to go to one of the newer engines with the common rail fuel system and computer control.But you can buy an awfull lot of fuel for what it will cost for a repower.
I have 2 4960's,both dyno around 260 hp,both over 10,000 hours,and they will outpull the 8420's on about the same amount of fuel in heavy tillage.
